Old 12-29-2010, 10:44 PM   #1
emil77
Lucas Oil Transmissions/Engine fix?
Hi!
Anybody had luck with the Lucas Oil brand? I was at Autozone today and noticed the Lucas Oil Transmission fix. It's supposed to help with the tranmission slipping. My truck kicks into first gear, could the Lucas Oil help?
Also, they have a product which will supposedly stop engine oil leaks. My truck is also leaking oil. Does the Lucas Oil products really work or is it just a waste of money?
http://www.lucasoil.com/articlelist1...ransmissionFix
http://www.lucasoil.com/products/dis...%20Stop%20Leak
Thanks,
Emil
1972 Chevy C20
emil77 is offline   Reply With Quote
Old 12-29-2010, 10:54 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Lucas Oil Transmissions/Engine fix?
The best that you can hope for your oil-burning/leaking situation is to reduce the amount that it burns/leaks. Those additives are not a substitute for bad gaskets/seals. Regardless of what is printed on the label. Those companies have highly-paid peeps that create that verbage and make us think that you can get a complete engine overhaul with one 8-oz can.
As for the transmission, I have used K-W products, think it was Trans-X. Did it help? Don't know. Did it make me feel better? Maybe a little. Did it fix the transmission? Not if it needed parts/seals, etc. Some of those additives may offer shift improvers, but you gotta remember that there are friction-inducing parts that deteriorate over time/miles. I don't think any additive is going to add friction material to the surfaces of any worn parts.
Lucas stuff is good, as long as you're just trying to enhance the lubrication properties of the engine oil.
Member Nr. 2770
Old 12-29-2010, 10:56 PM   #3
emil77
Nice, great info. Thank You!
Thanks,
Emil
1972 Chevy C20
Old 12-29-2010, 11:18 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
good stuff to limp along a little further.
Crap if you are trying to make something nice last longer.
Old 12-29-2010, 11:36 PM   #5
hchad18
hchad18's Avatar
I used it in a slipping turbo 350. Ran great after that. Not a daily driver and I'm not saying its a permanent fix but it will help you get along until a rebuild is possible.
hchad18 is offline   Reply With Quote
Old 12-30-2010, 10:20 PM   #6
nbrfd007
nbrfd007's Avatar
I have had good luck with Lucas products, My 71 Jimmy was starting to slip pretty bad in reverse and leaking seals, that was 6 years ago. Now the trans is finally going out. Not bad for two bottles of Lucas. The power steering Lucas works real good. Had a 72 Big Block Longhorn, Power steering only work when you turned left, puled the old fluid out, put Lucas in, started to work again. I think it is worth the try.
nbrfd007 is offline   Reply With Quote
Old 12-30-2010, 10:25 PM   #7
fine69
fine69's Avatar
My 91 Roadmaster wagon was developing a vibration in the trans.
I just changed fluid, added a quart of Lucas trans to it.
Fixed the problem.
I swear by Lucas.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 12-31-2010, 12:29 AM   #8
jakeblues652
jakeblues652's Avatar
i can say the tranny 'goop' works good. but it might take a while to pour out of the bottle..espisally if its cold out.
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains
Originally Posted by Dan in Pasadena View Post
Did you figure out how to fix it?...I mean with other than a BFH?!
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there
jakeblues652 is offline   Reply With Quote
Old 12-31-2010, 12:39 AM   #9
emil77
Hmm, lots of good info! Thanks.
Thanks,
Emil
1972 Chevy C20
Old 12-31-2010, 12:40 AM   #10
63chevyll
gets board easy.......
63chevyll's Avatar
my buddy puts the quart in boiling water and it drains much nicer. ive even put it in the microwave
the trans stuff stops my TCC from shudering once per year. I know i need a new Torque converter, but ive been limping it along for 3 years this way,
new fluid and a bottle of lucas a year. Yeah ill have to fix it sooner or later but dont have the cash for an Alison rebuild at the moment
63chevyll is offline   Reply With Quote
Old 12-31-2010, 12:44 AM   #11
jakeblues652
the couple times ive used it it was set on top of the waterjacket on my woodstove for about 30 min. you couldnt pick it up without a welding glove on. it came out quick needless to say
