Old 12-30-2010, 12:35 AM   #1
vjjack04
vjjack04's Avatar
Long tube headers for small block - 55 3100
I have asked this before, but has been a while....anyone proud of their in-side fender long tubes for a 55-57 3100....I am looking for a pair....
vjjack04 is offline   Reply With Quote
Old 01-05-2011, 08:17 PM   #2
DransportGarage
DransportGarage's Avatar
Re: Long tube headers for small block - 55 3100
I'm interested in this too. Is there a long tube set available that will fit a slightly lowered '55-'59? My cab steps are about 7" off the ground.
Thanks,
Bob
DransportGarage is offline   Reply With Quote
Old 01-05-2011, 10:09 PM   #3
vjjack04
vjjack04's Avatar
I was informed by a forum member that 55-57 chevy passenger car long tubes have worked for some of the truck applications.....
Old 01-05-2011, 10:33 PM   #4
entourageguy
Yellow truck club
entourageguy's Avatar
I've got a set of 3/4 length from an S-10 V8 conversion
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 01-06-2011, 10:16 AM   #5
DransportGarage
Thanks Vjjack04. I bought a set at a local swap meet ($40) that were supposed to be for a '55 truck. They look exactly like the ones on my '55 sedan. I think they would have worked if I had retained the stock truck height. They're too long now that the truck is lower. If I don't hear more on this thread I may just have to go to a pair of block-huggers.
Old 01-06-2011, 01:16 PM   #6
dan76
I just viewed the Skip White web site and they have a set of stainless block huggers available. I'd be interested in hearing from folks who've used them.
dan76 is offline   Reply With Quote
Old 01-06-2011, 03:00 PM   #7
DransportGarage
Here's a link to the ad: http://www.skipwhiteperformance.com/...?Item=8808-HDR. They show a great view of the flange mating surface, but not the welds that show just below the valve cover. I'd be interested in seeing that, if for no other reason than the Chinese block huggers I have seen have really ugly welds. The price is great at $164.95, but the flanges are plated steel, which will rust.
Old 01-06-2011, 05:16 PM   #8
apache1958
looks like the same ones i got from iowa,one had welds burnt through the tubing leaving pinholes and a few months later i tried to bolt them on and they hugged the block so tight they won't bolt up.
apache1958 is offline   Reply With Quote
Old 01-06-2011, 11:43 PM   #9
JMR5
JMR5's Avatar
I'm running hooker super comp headers on my 59 and they fit around the stock steering perfectly. The part number is 2819-1HKR. They are pretty expensive from most places, but I stumbled across a set on the Holley ebay store as scratch and dent and they were 80% off! You might check their site from time to time. http://stores.ebay.com/holleyperformance
JMR5 is offline   Reply With Quote
