12-30-2010, 02:42 AM | #1 |
ok whats a SPID
title says it all
12-30-2010, 02:46 AM | #2 |
Petroleum User
Re: ok whats a SPID
Its the tag on the inside of the glovebox door. Service parts identification. Tells what options the truck came with from the factory.
12-30-2010, 03:42 AM | #3 |
Re: ok whats a SPID
then there is a build sheet that is under the seat but f your seat is not original to your truck, chnces are it is long gone build sheets tell more then your spid
12-30-2010, 05:15 AM | #4 |
Re: ok whats a SPID
is the buildsheet just layin loose or is it tucked under the seat somehow?
12-30-2010, 10:29 AM | #5 | ||
"I ain't nobody, dork."
Re: ok whats a SPID
It's sandwiched between the seat cushion foam and the metal springs underneath. Usually need to pull the seat to get it out in one piece.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
12-31-2010, 03:02 AM | #6 |
Re: ok whats a SPID
So I gotta pull the seat, cut the cover and foam, pull the foam back and its between the foam and springs, is it on the drivers side, near the middle or toward the passenger side or is it just a random placement between the foam and springs
12-31-2010, 03:06 AM | #7 |
Re: ok whats a SPID
It would be on the outside of the foam and cover. Under seat or behind seat. If you can't see it just from looking under the seat or behind the seat it aint there.
72 Cheyenne Super 80 Silverado Blazer 2wd Last edited by sameyrasmea72; 12-31-2010 at 03:07 AM. |
12-31-2010, 04:20 AM | #8 |
Re: ok whats a SPID
they most fften come out in peices and you have to tape em back up and put em together i foundout that my 67 was made in the morning of march6 1967 and found out my truck was made in fremont, califorinia and sent to san jose ,steven creek dealer ship
12-31-2010, 07:00 AM | #9 |
Re: ok whats a SPID
A spid....
Happy New Year.....don t. .... |
12-31-2010, 07:09 AM | #10 |
Re: ok whats a SPID
thanks don, so i knew what a SPID was, just didnt kno thats what it was called, now i know more lingo
12-31-2010, 10:43 AM | #11 |
Re: ok whats a SPID
this was missing from my truck, can you find replacements?
12-31-2010, 10:53 AM | #12 |
Re: ok whats a SPID
mine is missing too, most likely no possibility of a duplicate
12-31-2010, 11:14 AM | #13 |
Vintage 4x4s
Re: ok whats a SPID
I think Chipflyer (member here) can make a new one for you
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
