12-30-2010, 09:19 AM | #1 |
Engine Swap to 79 -84 350 sbc pulley / water pump / harmonic balancer question
I bought a long block from a 79 - 85 model Chevy from a local guy and started to re-assmble it the other day. I ordered a water pump for a 72 Chevy and when I tried to install it doesn't fit because of clearance with the timing chain cover. So I returned it and got one for that model and now I am concerned about all my pulleys lining up.
Here is my question. Can I take a timing cover off an older model and then return to the original pulleys or will I need to change all my pulleys to later models? Also will the timing marks on the harmonic balance be in the wrong place if I use a harmonic balancer from the 79 - 85 model? Can I put the balancer from a 72 SBC on and everthing work out okay? Thanks in advance for your help. |
12-30-2010, 05:30 PM | #2 |
Re: Engine Swap to 79 -84 350 sbc pulley / water pump / harmonic balancer question
It should clear the timing cover. The timing tab may be interfering with it. I would use the original short pump system & all your original parts. You can use the old balancer but you can hold it up against the newer one & line up the keyway's & remark the old one. I don't think you can use the older cover as they changed the area that fits up against the pan somewhere around that era.
12-30-2010, 10:12 PM | #3 |
Thanks Wrenchbender Ret. I brought home a parts truck 3 days ago and it has a short water pump. I am going to use it to see where my problem is. Thanks for the info this will save me a lot of time and trouble trying to find brackets to replace my old ones.
Thanks again, Keith |
