Old 12-30-2010, 02:43 PM   #1
Navy Mechanic
Navy Mechanic's Avatar
Question Was my truck originally a long bed?
Was underneath my truck yesterday re-installing the seat (some anchor nuts gone so used bolts/nuts) anyway.....noticed some weld beads just aft of the forward cab mounts. Further investigation revealed that the aft cab mounts were welded vice riveted. Take a look at the pics...whatdya think? Former long bed?
"Once a Chief, always a Chief!" MCPO (ret)
03 2500HD- 'Daily driver'
67 Short Fleet- 'Drivable project!'
11 Malibu LTZ- 'The Wife's ride'
Navy Mechanic is offline   Reply With Quote
Old 12-30-2010, 02:46 PM   #2
19seventeeCustom
Re: Was my truck originally a long bed?
is the spid visible?
19seventeeCustom is offline   Reply With Quote
Old 12-30-2010, 02:52 PM   #3
Navy Mechanic
It's usually on the inside of the glove box door, right? If so...it's long gone.
Old 12-30-2010, 02:58 PM   #4
19seventeeCustom
yes inside of glovebox, Its tough for me to tell in these pics, but I dont remember my truck having that weld along the frame in that area, but im sure someone more knowledgable will chime in
Old 12-30-2010, 02:59 PM   #5
BIGBLU 72
BIGBLU 72's Avatar
my long bed for sure does not have any welds like that on the frame
68 C10 LWB 2/4 drop 406/th400/3.73posi
04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD
BIGBLU 72 is offline   Reply With Quote
Old 12-30-2010, 03:10 PM   #6
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
It looks like it probably was. It doesn't look like they did a very good job of alighning the frame rails either. Is there some sort of reinforcement plate installed on the inside of the frame rails? If not there needs to be. Take a look at the rear ends of the frame to see if they look like they have been cut off. (Saw marks, cutoff wheel marks, or toarch marks.) WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 12-30-2010, 03:12 PM   #7
VA72C10
VA72C10
VA72C10's Avatar
Looks to be a shortened frame. Is there any extra gusseting/bracing on the inside?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 12-30-2010, 03:13 PM   #8
Classic Heartbeat
Uppon further inspection, the frame rail allignment is off in oppisate directions on each side. One side up and one side down... I would fix that if it were mine. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 12-30-2010, 03:14 PM   #9
71swb4x4
71swb4x4's Avatar
And the quality of the job isn't that great. The two halves aren't even lined up very well. I would not be a happy camper if that was mine.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 12-30-2010, 03:15 PM   #10
Classic Heartbeat
They also have the front cab mounts in up side down. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 12-30-2010, 03:27 PM   #11
VA72C10
VA72C10
VA72C10's Avatar
It might be worth looking for a shortbed frame to swap everything on to....
Old 12-30-2010, 04:05 PM   #12
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
look here for frame.
http://67-72chevytrucks.com/vboard/s...d.php?t=437914
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-30-2010, 04:13 PM   #13
Navy Mechanic
I'll have to lift the front end to get under and see if there's any extra bracing on the inner frame.
The frames are 'misaligned' the same on both sides. Aft frame is lower at the bottom.
Don't have the money or shop space to swap everything to a new frame. It drives straight and sits level...guess I'll strengthen the weld points as needed. Amazing the demons that come out when you start looking close.
Old 12-30-2010, 04:17 PM   #14
I'd say it was shorted or maybe frame was repaired from an accident? Do the frame VIN# and the VIN of your title match?
Old 12-30-2010, 04:19 PM   #15
Classic Heartbeat
I would flop the cab mount cushions also. They are in wrong. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 12-30-2010, 04:30 PM   #16
VA72C10
VA72C10
VA72C10's Avatar
If the frame doesn't have any additional bracing on the inside, I wouldn't feel comfortable riding in it....the way that is welded straight...with no additional bracing it is definitely unsafe.
Old 12-30-2010, 04:51 PM   #17
Hubscrub
Cruzin
Hubscrub's Avatar
i agree i would weld some plates on there and go with that
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 12-30-2010, 05:22 PM   #18
Navy Mechanic
There is additional bracing...kind of. The upper flange was cut off the forward C-Channel leaving 12" of web and lower flange extending into the aft channel and it's welded at that point. I've posted the clearest picture I could get.
Opinions? Does this suffice? I'd think if the web was also welded to the aft frame at the upper horizontal seam, where the flange was removed, it would definitely be strong enough.
Old 12-30-2010, 06:18 PM   #19
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
So they overlapped the rails?
screamin_c10 is offline   Reply With Quote
Old 12-30-2010, 06:21 PM   #20
Navy Mechanic
That's what it looks like....
Old 12-30-2010, 06:49 PM   #21
MistaGavin
MistaGavin's Avatar
I can understand not being able to get a different frame but that definitely should be reinforced.
MistaGavin is offline   Reply With Quote
Old 12-30-2010, 07:13 PM   #22
fixit-p
fixit-p's Avatar
The fact that it is over lapped makes me personally feel allot better about the splice, I've seen and done allot of frame stretches over the last 21 years and I always cringe when I see one that was spliced at 90* with the top and bottom flanges. The fact of the matter is that no matter what you do in that area you create a stress riser. We normally glove the chassis either inside or out and bolt the glove in as opposed to welding it, because welding just moves the stress riser instead of distributing the load over a larger area.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 12-30-2010, 07:17 PM   #23
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
If that things overlapped like I think it is, it wont need "fish-plating" or additional reinforcement. That may be a bit "unorthodox" but yet very effective. You can see that the cab mounts were welded but as mentioned above, the cushions are installed upside down. Correct that and your good to go. IMO Thats a professional opinion by the way, Im a union structural steel "Ironworker" certified welder for well over 33yrs. The reason it hasn't broken yet, is because its not going to. "just sayin" Whats up with the "Mexican" comments? Thats BS!
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 12-30-2010, 07:37 PM   #24
screamin_c10
My issue isn't the strength of the overlap...although I agree the webs probably should have some Grade 8 or better bolts going through. My issue is the way they staggered the frame rails in order to achieve the overlap. The one rail higher than the other is obvious, but in order to slip the rails into one another either the frame needed to be pinched or spread.
And I agree the Mexican comments are uncalled for...
Old 12-30-2010, 08:29 PM   #25
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Looks like the top flange was trimmed off to allow it to slide inside the other half. No spreading required.
How far do the channels overlap? That is what will determine the strength.
Doesn't look like your hauling large loads with this truck, should be fine and its always something you can periodically inspect for cracks.
FWIW, the frames on the newer 2500hd's are welded in a similar manner. They tow upwards of 16,000 lbs with them.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
