12-30-2010, 09:29 PM | #1 |
205 Output
I have a 53 chevy pickup on a 86 4 x4 frame
zz - 4 and 205 transfer case from a 1/2 ton It has the flange type mount on the front the problem is the stock drive shaft comes too close to the tranny is it possibel to change to an out put for a plain u joint instead of the constant velocity setup I need 4x4 only at low speeds and on dirt etc Gene |
12-31-2010, 03:12 PM | #2 |
Re: 205 Output
Are you saying the drive line is too long? Non CV can be used if the angles are right at the pinion & T-case. Take pics I'ts fairly easy to shorten a drive line if you can weld... BTW ~ Love the rig!!
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks Last edited by Burt4x4; 12-31-2010 at 03:13 PM. |
12-31-2010, 04:49 PM | #3 |
Re: 205 Output
The problem with no CV on the front is that you need approximately the same angles on both yokes. The tcase side is going to be pitched up towards the front on the truck while the axle would need to be rotated down in the back to match. Check out Tom Woods drivelines website for a better explanation with pictures. It might work for offroad only. Cool truck.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
12-31-2010, 08:23 PM | #4 |
Re: 205 Output
many of the older trucks in the 50 60s era had no CV joint
I have none in my Cj 7 Gene Sharp |
