12-30-2010, 10:03 PM | #1 |
what gasket sealer works best?
i have been having problems gettin my water pump in my 97 blazer to seal right... ive tried the permatex black gasket maker and im havin no luck. i seem to keep blowin the gaskets out. when i change the water pump in my 98 gmc i never had this problem, but it think i used a different gasket sealer. i cant remeber what kind i used on that truck. any help on what everyone uses would be helpful. im gona try another water pump and new gaskets this weekend thats why i was wondering.
12-31-2010, 01:56 AM | #2 |
Re: what gasket sealer works best?
1969 307, t350 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
12-31-2010, 09:02 AM | #3 |
one the best going right there, but I would check to make sure that ABSOLUTEY all the old gasket is off the block first (a good scraper and then sandpaper or a gasket removal pad http://multimedia.3m.com/mws/mediawe...SevTSeSSSSSS--) if even a small peice remains it will let the pump sit off enough to allow a path for leaking to occur. I may not change them everyday but I've sod enough and seen this before to know a common solution. And yes even the professional rush tgrough the simple job and have this issue sometimes.
just a paint guy working hard and driving GMC's |
12-31-2010, 04:18 PM | #4 | |
#16876
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
01-03-2011, 07:27 PM | #5 |
well i got it takin care of, i think my old water pump had a crack in one of the bolt holes case it was all messed up right there, but that water pump gave me problems since i put it on last year. i got a new one with lifetime warrenty on it and seems to be ok now. thanks for all the input!!
01-03-2011, 10:48 PM | #6 |
BAD BOW-Silverado XST
The last sealer you'll ever use!! I use it on intake gasket bolts. No oil seepage anywhere. |
