Old 12-30-2010, 10:04 PM   #1
scotterdog
MII spring rates
Hi all, we are getting ready to order the parts to put a MII ifs under our 53 and im hoping you all could give me some advice on choosing what spring rate we need. the truck has all its stock sheet metal with a 305/th400 combo, if that helps.
thanks,
scott
scotterdog is offline   Reply With Quote
Old 12-31-2010, 11:10 AM   #2
weldvair@embarqmail.
Re: MII spring rates
I use 4 cyl springs with one coil cut. This seems to be what most shops do.
Don
.............after reading my post...........I meant to say with 1/2 of a coil, not 1 coil cut.
weldvair@embarqmail. is offline   Reply With Quote
Old 12-31-2010, 12:31 PM   #3
mr48chev
mr48chev's Avatar
A lot of guys tend to want to put too high of rating of springs in and ruin the ride they are looking for.
As Weldvair said, the 4 cylinder springs seem to work quite well in most instances.
Old 12-31-2010, 05:41 PM   #4
Atomsplitter
Atomsplitter's Avatar
While your looking at spring rates also look into a sway bar if the kit doesn't already come with one. It, along with the correct springs, will give a much nicer ride and cornering.
Atomsplitter is offline   Reply With Quote
Old 12-31-2010, 11:09 PM   #5
scotterdog
Thanks guys! we are getting a parts kit from speedway motors and gonna use a chassis enginering bolt in crossmember. the tech guy at speedway said we would be happy with a 375lb spring and thats just a bit on the stiff side of medium. all you and a truck guy my wife works with are saying softer, so i think im gonna go with springs a few steps softer than the 375lb ones.
thanks again!
scott
Old 01-01-2011, 10:45 AM   #6
52 Rat
52 Rat's Avatar
thanks again!
scott
I went with the 350# spring. I have the Heidts kit. I have a rather heavy engine with the lq4 6.0L.
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671
52 Rat is offline   Reply With Quote
Old 01-01-2011, 10:50 AM   #7
I have used the must II IFS over 10 times & experimented with many springs
........do not use anything but 4 cyl springs with 1/2 coil removed.
Don-Mech Engr
Old 01-01-2011, 12:53 PM   #8
scotterdog
Hey Don, do you know how many pounds the spring rate is on those 4 cyl springs? dig your truck!
thanks,
scott
