Old 12-30-2010, 10:10 PM   #1
brn agn
brn agn's Avatar
1967 Rear Axle (3.73) and Trailing Arms
I have a rear axle and trailing arms from a 2WD 1967 short bed. It has an open carrier with 3.73 gears with 6 lug axles. The trailing arms will need to be cleaned up, but do not appear to be rusted through anywhere. $150 and this will need to be picked up locally in Youngsville, NC
Per board rules, please reply to this thread if you would like to purchase these items.
1969 C10 SWB Project Charity Case AKA "Roscoe"
1971 Cheyenne Super A Combined Effort
The Service Station-A practical ministry for those in need
brn agn is offline   Reply With Quote
Old 01-06-2011, 05:01 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: 1967 Rear Axle (3.73) and Trailing Arms
ttt
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 01-06-2011, 07:28 PM   #3
2wd73blazer
are the 67 axles shorter than the 72? if so i am interested in the axle
2wd73blazer is offline   Reply With Quote
Old 01-06-2011, 07:56 PM   #4
gcburdic
Restoration Virgin!
gcburdic's Avatar
Hey Brad....I don't think Jesse will mind if I answer....yep they are...do you want the whole setup??
Geoff with a G
Old 01-06-2011, 08:26 PM   #5
2wd73blazer
how much shorter and I am really only interested in the axle
Old 01-06-2011, 08:37 PM   #6
gcburdic
Restoration Virgin!
gcburdic's Avatar
I believe I read 3/4 of an inch each side for a total of 1.5" shorter
Geoff with a G
Old 01-06-2011, 08:56 PM   #7
brn agn
brn agn's Avatar
We can take some measurements for you this weekend. Just let us know where to measure to and from on the axle so we are comparing apples to apples.
Old 01-06-2011, 09:20 PM   #8
2wd73blazer
from backing plate to backing plate is the best way I guess?
Old 01-08-2011, 07:03 PM   #9
brn agn
brn agn's Avatar
Geoff and I measured the rear axle today. As you can see below, it is around 55 1/4". We also measured the axle in my truck, which is from a 71 and it is 57" wide at the same point.
If you are still interested in the axles, let's talk and see if we can work something out.
Old 01-17-2011, 01:08 PM   #10
brn agn
brn agn's Avatar
Rear axle and trailing arms are sold.
axle rearend rear end swb
