12-30-2010, 10:11 PM | #1 |
Disk brake ???
I got disk brakes for my 67 from a junk yard last year. I went to the part store to get new rotors and there is no listing for a 1967-1972 6 lug disk
can someone tell me what year has 6 lug disk. I found them at LMC but shiping is half the price of the rotors. Thanks Lee |
12-30-2010, 10:17 PM | #2 |
67-72 parts collector,…
Re: Disk brake ???
No factory 6-lug disc rotors.
They are all after market. Throw away your LMC catelog. They are good for pictures. That's about it. There are better companies to buy parts from. CPP, ECE, POL, GMC Pauls, etc. all sell 6-lug "aftermarket" rotors for your front suspension. What year truck did you get your parts from?
12-30-2010, 11:14 PM | #3 |
Re: Disk brake ???
I'll have to disagree with the last post. I have'nt found the pictures to be that good.
12-30-2010, 11:37 PM | #4 |
Roadtrip!
Re: Disk brake ???
No factory 6 lug disc brakes in 67-72...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
12-31-2010, 12:08 AM | #5 | |
Re: Disk brake ???
12-31-2010, 12:14 AM | #6 | |
Re: Disk brake ???
Care to explain. That's a pretty broad statement for all parts? Suspension parts? Sheetmetal? What? I personally won't buy from LMC. But suspension stuff,.... from say,... ECE doesn't come from Taiwan.
12-31-2010, 12:30 AM | #7 |
Re: Disk brake ???
I got some control arm bumpers from GMC pauls Made in India with LMC part #'s on them. I got 6 Lug rotors from CPP made in China. I got brake hoses from POL made in China along with some front drop springs that the paint was terrible on. I got some patch panels from ECE that were counterpart parts which are made in Taiwan and the labels were half peeled off to help disguise them. The good quality parts that you do get from them can be more than likely bought at any auto parts store for about the same if not less price with no shipping charge. No offense thats just the experience I have had with aftermarket parts.
12-31-2010, 12:41 AM | #8 | |
Re: Disk brake ???
id really appreciate if you guys stop bashing each brands and get back to the question-i would like to know what calipers they are and what rotor would work, because i hope to get 6 lug discs for my truck soon.
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains Quote:
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there |
12-31-2010, 12:46 AM | #9 |
Re: Disk brake ???
Did you try napa? Aftermarket isnt all bad, i orderd a fuel sending unit from Maines Trucks from this forum and had nothing but great experiences with that company... Try them.
1969 Chevy c20(Miss Hackjob) |
12-31-2010, 12:50 AM | #10 |
Re: Disk brake ???
jakeblues652,... here's your personalized answer in another members thread.
(Also,... this question is answered almost every day here on this board) All 6-lug "aftermarket" rotors are copies of the 71-87 5-lug (1.25" wide) rotor that has been cast as a blank rotor and then drilled 6-lug. Any parts store 71-87 caliper will work as long as it's for the HD rotors. (not the light duty 1" rotors) Any 73-87 brake pad will work. 71-72 rubber hoses will work. 65-70 "conversion" rubber hoses will work. The spindle has to be the oem HD 71-87 spindle. Or any aftermarket standard or drop spindle for 1.25" wide rotors. I hope this helps,...
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-31-2010 at 12:53 AM. |
12-31-2010, 12:52 AM | #11 |
Re: Disk brake ???
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
12-31-2010, 12:52 AM | #12 |
Re: Disk brake ???
angelo 32806,... sorry for the thread jack.
12-31-2010, 01:00 AM | #13 | ||
Re: Disk brake ???
and MY "personalized" answer is right along the lines of what angelo first asked. if they did not make rotors for these years trucks what else will he use but rotors from another model/year. not trying to start anything, but common sense man. because my "personalized" answer probably helped angelo. the quote part above was uncalled for.
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there Last edited by jakeblues652; 12-31-2010 at 01:02 AM. |
12-31-2010, 01:07 AM | #14 | |
Re: Disk brake ???
They did not make a 67-72 6-lug rotor. They also didn't make a 73-87 6-lug rotor. SO,... the aftermarket came up with a solution. Use,... 71-72 spindles. Or use 73-87 spindles, (HD version only). Bolt on their "new" aftermarket 6-lug rotors and be done. All other parts can be purchased locally. (this includes caliper, bearings, seals, brake pads, and hoses)
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-31-2010 at 01:08 AM. |
12-31-2010, 01:09 AM | #15 | |
Re: Disk brake ???
What year donor vehicle were the parts taken from? I was going to save my answer until I had more info.
12-31-2010, 08:21 AM | #16 |
Re: Disk brake ???
The parts came off a 1969 Or thats what thay told me.
I got a arms spindles rotors and calipers all still togeather and cut uff from the frame. I just bade a call told them what i wanted and picked them up never saw the truck. I saw a 1967 camper special at a car show and was told it was a factory 6 lug disk ? Is there any way to tell what spindles I have and if I can buy 71-87 hd disks or if the ones I have are machined 5 lug rotors Thankyou for all the info it has been very helpful |
12-31-2010, 08:44 AM | #17 |
Re: Disk brake ???
factory had no disc brakes of any kind on trucks till 71 and they were 5lug
12-31-2010, 11:47 AM | #18 | |
Re: Disk brake ???
Can you post some pics of the parts you bought? They did have power brakes in 6-lug between 67-70,... but they were all drum brakes. You are also going to need to change your master cylinder and proportioning valve to make the disc brake swap work on your truck.
12-31-2010, 12:07 PM | #19 | |
Happy to be here
Re: Disk brake ???
We have a forum policy to answer questions rather than suggest "Use the search feature" like so many forums do. Unfortunately that policy allows members to ask the same question over and over with out taking the time to "read every brake thread thats up every day. " If you want polite answers, please take the time to research the question first.
12-31-2010, 01:22 PM | #20 | |
Re: Disk brake ???
Trucks that were 4x4's that is, lol! Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. Last edited by chipflyer; 12-31-2010 at 01:32 PM. |
12-31-2010, 01:52 PM | #21 |
Re: Disk brake ???
they are different bearing sizes
1990 chevy 4x4 with a 1940 IHC body |
07-14-2011, 04:19 AM | #22 |
Still plays with trucks
Re: Disk brake ???
Kind of back from the dead but I just did this not long ago...Easy bolt on with even easier to find parts than 71-72 K10 stuff. I converted my drum brake open knuckle Dana-44 in my 69 to disc with caliper brackets, calipers, spindles, rotors & 4x4 hubs from a donor square body. Simple bolt-on installation. The wheel bearing size changed on the inners so you can't reuse the drum brake spindles. The bolt pattern is the same though so no big deal, you have to pull them any way to install the disc brake caliper bracket.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
