Old 03-09-2003, 05:40 PM   #1
Reumster
L.E.D. Freak
Reumster's Avatar
Question Front Bag brackets/are drop spindles needed?
Ok right now I have SoLo lowered lower a-arms, and I think 1" lowered springs. I have to get stock lower arms.
What type of mods will I need to do? Do I have to get drop spindles? I want the bags to sit square at ride height. Also I want maxium lift. My rear is sitting on bags and axle on frame no air, and no c-notch. I want the front to sit level with the rear. Aired out. My front is droped about 4" and with the rear on the axle the front is higher than the rear aired out. My ride hieght I want a couple inches above the frame in the rear. Eventually I want to C-notch the rear. but will leave the notch bump stops because with my rear tank on my blazer I don't want to get to close to the ground. 1" lower aired out is plenty low for aired out on bump stops. And I don't want to mod my bed floor.
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 03-09-2003, 09:50 PM   #2
Reumster
L.E.D. Freak
Reumster's Avatar
NSANE68
How does this front kit compare to say the air ride kit? What size port hole is in that bracket? My question is I have SoLo dropped a-arms up front have you heard of anyone using these brackets on them? They are stock arms with relocated ball joints. Do I need drop spindles with these brackets? With these brackets aired out up front will it sit on the bump stops? Is there any modification to the steering stops with them? Like I've seen on other bag buildups?
(406)675-8082
Old 03-10-2003, 12:00 AM   #3
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
The brackets accept up to 1/2" fittings and line. I would say they would work on your drop arms, maybe a little trimming.
On my truck with 2.5 drop spindles and bags the crossmember clears the ground by 1.25", so with your drop arms and spindles you could plant the crossmember. If you want clearance like mine then do one or the other.
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
Old 03-10-2003, 12:10 AM   #4
RACING29
I have heard with drop A-Arms it will mess the bags up and make them blow. Also is it nessecary to run a lower bag mount in front- Imean do you absolutely have to have one or will it just set in place like a regular spring? THanks
1967 Chevy truck, R1 racing seats, 4 point racing harness, 4/6 drop, primered blue, soon to be shaved, 350- 060. over, flat top pistons, Eagle rods, Edelbrock Aluminum heads, 1.5 Scorpion roller rockers, Lunati 515" cam, mallory ignition, Holley 750 double pumper carb, Built 350 turbo trans, 2500-2800 boss hog stall, 20 gallon aluminum fuel cell!!!
RACING29 is offline   Reply With Quote
Old 03-10-2003, 12:20 AM   #5
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
On these trucks you need a bag mount, the cups are not deep enough to deem it safe. And the lowered control arms is not entirely true, take a look at Turner enterprises, he has a kit of, 2.5" drop spindle, 2" drop arm, 1.25" notched crossmember and a newley developed lower conrol arm relocater. He claims this kit will lay the pinch weld on the ground. PRETTY IMPRESSIVE!! Not trying to drive biz away from myself but the guy is pretty damn GOOD
68 chevy money pit
51 chevy belair
95 Honda 900RR
Old 03-10-2003, 11:42 AM   #6
Reumster
L.E.D. Freak
Reumster's Avatar
I have to get stock lower arms. My lower So-Lo arm is tweaked and the bushing nut is poped off. I don't have drop spindles, and don't really want to spend the money on them but I guess if I have to I will. I don't know maybe I do have drop spindles how can I tell? This blazer was lowered when I bought it. I like them brackets though NSANE
(406)675-8082
