Old 02-23-2002, 10:04 PM   #1
turbo
Post v-8 s-10
I'm building an 86' s-10 w/a 350 v-8 and I would like to keep the 4-speed stick thats in it.Would it hold up to a 350?The truck came from the factory w/a 2.8 v-6 and 4-speed w/a posi rearend.I have a narrowed 12-bolt posi rear i'm putting under it.I have a v-8 bell housing from a 1969 GMC truck would this work w/the 4-speed?The motor and bell housing came out of the same truck.Any help would be appriciated
1965 CHEVROLET C-10 SHORT-BED STEP-SIDE W/ 409 AND A 4-SPEED
1966 PLYMOUTH BARRACUDA W/ 360 PLYMOUTH AND A 727 TORQUEFLITE
1983 PONTIAC FIREBIRD W/ 350 CHEVY AND A 5-SPEED
1989 CHEVROLET SILVERADO W/ 350 CHEVY AND TH-700R-4
turbo is offline   Reply With Quote
Old 02-24-2002, 11:08 AM   #2
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Post
The tranny won't be near strong enough. I'm not sure if the bell housing would fit or not. Best bet would be automatic or finding a 5 speed out of a newer truck.
72 Chevy C/10
87 Chevy Silverado 4X4
www.geocities.com/chevylwb/chevylwb.html
Aberdeen South Dakota
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 02-27-2002, 06:43 PM   #3
blazer boy
Post
if you located a t-5 manual out of a 2wd s-10 you could buy a clutch and bellhousing kit from summit or jegs , kinda expensive though , but definetly better than the old 4 speed. or you could swap in a getrag 5 speed out of a newer body style s-10 (94-02) as long as it is out of a 4.3 powered truck
blazer boy is offline   Reply With Quote
Old 03-01-2002, 11:26 PM   #4
Z16
Post
A v6 transmission definately won't hold up to a V8 for any lenght of time. The 2.8 tranny won't work, and while the 4.3 one will, it will break if you run it hard. If you want a cheaper four speed, look for a super T-10 or Muncie M-21 out of a late 70s early 80s Camaro. There are still quite a few around, they are reasonable to rebuild, and are plenty strong for a mild V8 S-10. A better choice if you wanted overdrive is the T-5 from a mid 80s-early 90s Camaro/Firebird, but they aren't quite as strong and probably more money. A good clutch setup is the hydraulic setup from a 4.3 S10. It's all bolt in.
98 GMC Sierra Ex Cab, cowl hood, Euro LED lights, 30 bar billet, Whipple Supercharged 350 Vortec: Forged flattops, E-Tec aluminum heads, Comp Cam, Scat crank and rods, Granatelli Mass air flow, Headers, Flowmaster exhaust , Complete MSD Ignition, Custom Tuning, intake spacer , ported throttle body, AC Delco port injection upgrade, Roller Rockers, Power Pulleys. Gear Vendors Overdrive. Soon to hit a dyno. 2/4 drop(for now).
95 Chevy S-10 Ex Cab 4.3 5 Speed 2/3 drop, Euro lights, billet grill, More to come. The Daily Driver
Z16 is offline   Reply With Quote
Old 03-02-2002, 12:17 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
The T-5 is a POS and will not last behind a 350...there's a reason it was never offered behind one.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
Need to pick up the one ton Longhorn with a PONTIAC 350/350soon.
Thanks every one!
Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 03-04-2002, 03:47 PM   #6
kickinbigblock468
Post
your best bet is to go with a TH700-R4 automatic trans. It will make life a lot easier and finding one is no problem.
1981 Chevy Silverado
468 cid big block
Edelbrock Tunnel Ram Dual Quad Intake (2 600cfm edelbrock)
Dual 3" exhaust
468 cid big block
11.5:1 compression
Comp roller cam and lifters
Comp cams roller rockers
Steel Manley connecting rods
MSD-10 ignition with Pro Billet distributor
Pete Jackson gear drive timing gears
Saveing for a set of Alluminum heads and an 8-71 Blower
kickinbigblock468 is offline   Reply With Quote
