Newb Steering Question
I recently picked up a 69 swb C10. Currently going through it fixing small issues and noticed that the steering centerlink is resting on the engine cradle. The truck sits lower than stock, though I don't think the front is lowered. I think the front springs are just old. Rear has similar old springs, but also has 2" lowering blocks.
Is this normal? |
Re: Newb Steering Question
Tried searching without any luck
69 C10 SWB LY6 T56 70 Chevelle SS 396 4spd |
Who's got steelies?
![]() Join Date: Feb 2006
Centerlink in backwards.
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
Thanks OldGold. When I flip it around, to the inner tie rods still connect on the engine side or should I move them to the front?
Cruzin
here is a couple of pics for ref.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
Thanks. Hopefully get it sorted out today
Watch out for your cornhole !
![]() Join Date: Jun 2003
Centerlink isn't backwards. The holes for the idler arm, pitman arm, and tie rod ends are tapered. No way to put it in backwards.
I considered that, but don't hold out hope that the P/O had any common sense. I will take a closer look shortly.
Based on the pics hubscrub posted, its not installed backwards. I also checked the cradle bolts and theres no signs that they are causing the problem
Were there different pitman/idler lengths available based on the year or options? Maybe its got the wrong parts installed?
69 C10 SWB LY6 T56 70 Chevelle SS 396 4spd Last edited by ADub; 01-01-2011 at 01:14 PM. |
#10 | |
Who's got steelies?
Here is a picture of the centerlink on my own truck. It has enough room to stick a finger between the centerlink and crossmember. ![]()
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel Last edited by oldgold70c10; 01-02-2011 at 02:03 AM. Reason: Added Pic |
My picture doesnt show it well, but my centerlink does have the offsets and its installed in the same orientation as yours.
I looked up all the part numbers for idler arms between the years and they are all the same (67-72). So Im stumped as to why the centerlink is resting on the cradle.
#12 | |
Who's got steelies?
#13 |
If I understand your questions correctly, yes the centerlink is offset up and towards the rear of the truck relative to the ears that connect to the idler/pitman arm.
The idler and pitman are in decent shape and nothing stands out to me as messed up.
#14 |
hello i know this is a old thread, but did you ever find the problem? Iam having the same problem,,,the link is resting on the cradle...thanks i appreciate it..
68 C/10 short bed 77 C/20 silverado long bed 05 GMC Duramax Crew |
#15 |
![]() Join Date: Jan 2007
hey there lou. here's a pic of how it should look...
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
#16 | |
#17 |
Its been a long time, if I remember correctly that first center link was tweaked and I obtained another center link. Its still close to the xmember, but doesnt touch except when the pitman arm starts coming apart on Hot Rod Power Tour.....
#18 |
thanks ,, i really havent fixed the problem,,,i have it all tightened down and it still is rubbing on crossmember...is it possible that i have it too low,,,i have 2.5 drop spindles with 4inch lowering coils....which i think cud be problem. thanks again...
#19 |
Your suspension drop is not related to the centerlink clearance at that xmember. The centerlink position relative to the xmember is fixed based on front frame horns and pitman/idler arm. These frames get damaged over time, certainly possible the front frame horns are bent down
