Old 12-31-2010, 06:56 PM   #1
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Stripped Lower control arm bushing!
I was installing new lower control arm shafts w/bushings on my 72' 1/2 ton 2wd and realized that the bushing was rotating with the shaft when I was trying to torque the bushings. What to do? New control arm? Can I weld/tack the bushing to the control arm until I can find a new replacement control arm? The threads in the control arm were questionable when I dismantled the shaft assembly! This drop is turning into a $$$ nightmare! Help Please? Thanks! Its the right side...;-)
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 12-31-2010, 07:30 PM   #2
Spoof
Spoof's Avatar
Re: Stripped Lower control arm bushing!
It was half a dozen years ago that I did mine but I do remember something about having the same concerns? I think it's normal for the whole damn thing to want to spin but I can recall what I did. Don't fret too much until someone with more knowledge can chime in...it may be sop that they spin.
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 12-31-2010, 08:01 PM   #3
Ironangel
Ironangel's Avatar
Thanks for the reply man The bushings shouldnt spin, only the shaft. The manual calls for for 130 ft lbs of torque, I didnt get half that before it let go! Its a pizz poor design if you ask me! Im going to smear some JB Weld on the threads and reassemble it, Ill go with that until I can find a replacement control arm. If that dont hold the bushing still Im going to tack weld the sob! Ive flirted with the idea of drilling and tapping for a set screw or a roll pin as long as it dont interfere with the shaft. "Happier New Year!"
"Two Seventy Two's"
02 3/4 ton Express
