Old 12-31-2010, 08:31 PM   #1
67chevy1series
67chevy1series's Avatar
67 72 power steering brackets vs 73 ^
i dont have a power steering pump yet but my dad has informed me that 67 72 comes down nad bolts with the motor mount ?? that is jack@$$!!!! but he said the square bodies had hem different can i use 73 and up if i dont want to have it bolt to the motor mount???
67chevy1series is offline   Reply With Quote
Old 12-31-2010, 09:02 PM   #2
john
member #16
john's Avatar
Re: 67 72 power steering brackets vs 73 ^
None of your pulleys will line up with 73-up long pump brackets.
john is offline   Reply With Quote
Old 12-31-2010, 09:09 PM   #3
67chevy1series
$hit! what would all of you consider
Old 12-31-2010, 09:53 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
BUY the correct 67-72 truck brackets for a short waterpump style, power steering pump.
Look in the classifieds or place a WTB ad.
I assume you have the correct pulleys and waterpump on your truck?
Keith
Convert to disc brakes.
Old 12-31-2010, 09:56 PM   #5
67chevy1series
i dont have any pullies but i do have the short water pump
Old 12-31-2010, 10:40 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
So you'll need the following for a short pump configuration.
Main crankshaft pulley
Secondary crank pulley
Water pump pulley
Power steering pump with reservoir
Power steering brackets (2 pieces)
Alternator brackets (2 pieces)
71-72 trucks used a slightly different ps pump bracket arrangement which was less prone to cracking than the earlier ones. Seek them out if you can find them.
Old 12-31-2010, 10:50 PM   #7
67chevy1series
Water pump pulley
thanks tx firefighter i have the bottom pullei i just dont have the water pump or powersteering pump or altenator
