Old 02-21-2002, 07:40 PM   #1
raychevy
Post Flowmaster
Okay im fixin on ordering the 389-42441 from jegs. Will that fit my 77' 350 ? Im also getting the 289-89006 dynomax header and manifold dial kit from jegs. Its all 2 1/4 The flowmaster headers are "A" style Will all that hook up to my stock manifold ? Thanks everyone im sure exhaust questions are getting old!
[This message has been edited by raychevy (edited February 21, 2002).]
raychevy is offline   Reply With Quote
Old 02-21-2002, 08:17 PM   #2
raychevy
Post
Heres some extra info to help
Flowmaster Street Mufflers - In-Out: 2-1/4''
Body: 13''
Style:A
Chambers: 2
Item # 389-42441 $ 59.99 $ 59.99 Flowmaster Street Mufflers - In-Out: 2-1/4''
Body: 13''
Style:A
Chambers: 2
Dynomax Header and Manifold Dual Kits - 73-87 Chevy PU 2WD 1/2, 3/4-Ton
Item # 289-89006 $ 109.99 $ 109.99
Old 02-24-2002, 04:54 PM   #3
powermad
Hillbilly Hotrod
Post
Yes those will work, if you look at the muffler that Dynomax recomends it is the A style of the Flowmaster.
I am going to get basicly the same set up for my K5 and Burb, but I am getting Hedman headers.
78 K5 on 3/4 ton axles.
69 K5, .060 over 350/465/205.
powermad is offline   Reply With Quote
Old 02-24-2002, 05:52 PM   #4
raychevy
Post
Thanks for the reply. I am looking forward to working on this project.
Old 02-26-2002, 10:27 AM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Post
Good post. I can use the same information on the kit. I just pickup two brand spanking new flowmasters for $50.0!! Now I just need one more cat and the kit!!!
Gerardo
1983 Custom Truck
TX Plates: "BAD BOW"
http://www.geocities.com/abetterchemist/
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 03-04-2002, 03:58 PM   #6
kickinbigblock468
Post
If you want some serious sounds from your truck you can buy a set of warlock mufflers. They have a bypass plug that is held on with 3 wing nuts. Noise isnt bad and when you want to hit the strip or sound good for a drive in just pop out the plugs. These things GRAB attention when the plugs are out!!
1981 Chevy Silverado
468 cid big block
Edelbrock Tunnel Ram Dual Quad Intake (2 600cfm edelbrock)
Dual 3" exhaust
468 cid big block
11.5:1 compression
Comp roller cam and lifters
Comp cams roller rockers
Steel Manley connecting rods
MSD-10 ignition with Pro Billet distributor
Pete Jackson gear drive timing gears
Saveing for a set of Alluminum heads and an 8-71 Blower
kickinbigblock468 is offline   Reply With Quote
