Old 01-01-2011, 03:46 AM   #1
4ton68
lift kit
Anyone know who makes a 10 or 12 inch lift kit for a 1968 chevy k20?? or someone that makes custom springs?
4ton68 is offline   Reply With Quote
Old 01-01-2011, 05:16 AM   #2
royo
royo's Avatar
Re: lift kit
a rear 8 inch spring 52 in long will give you about 12 inch of lift in the front but you will have to use a b52 spring kit from diy or move you factory perches up
it will also ride better
nickle and dime
royo is offline   Reply With Quote
Old 01-01-2011, 01:03 PM   #3
4ton68
Re: lift kit
alright thanks royo and when you say move the perches up how far and all that are you talking and what exactly do you mean by perches?
Old 01-01-2011, 01:05 PM   #4
4ton68
Re: lift kit
and who is diy i googled them and got nothing. do you have a site or number?
Old 01-01-2011, 02:02 PM   #5
Altec
Getcha Pull
Altec's Avatar
Re: lift kit
http://diy4x.com/
They make great products, and the guys who run DIY are cool.
If it was mine, I'd look at a shackle flip in the rear with 4" lift springs, and a 1" zero-rate. Then a B52 conversion in the front with 4" rear lift springs with a 1" zero-rate. Add a 1" body lift, and you are running a nice 10" lift that will flex nice, and ride decent.
The things that pop into my head that will need to be changed as well are longer brake lines, lengthened drive shaft, clocked rear leaf spring perches, maybe turned "C"'s in the front axle, and maybe a crossover steering.
Here is a thread about what you plan on doing.
http://67-72chevytrucks.com/vboard/s...d.php?t=412360
Honestly, this is a TON of work. Companies do offer factory leaf springs in a 10"-12" lift. The problem is simply that they are useless... They flex so little, and ride so bad you might as well solid mount your axles... If you are interested in doing it how Royo, and myself talked about then I suggest start researching the different areas of the conversion. It really won't be easy, or cheap.
How big of a tire are you wanting to run? At the end of the day, that is a lot of lift.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 01-01-2011, 02:13 PM   #6
4ton68
Re: lift kit
ive got 38.5 on it right now. ive been looking around trying to find exactly how much bigger i want to go. right now the truck is hugging the tires and i want to get some more room between the tires and truck
Old 01-01-2011, 07:53 PM   #7
royo
royo's Avatar
Re: lift kit
Originally Posted by Altec View Post
http://diy4x.com/
Good info
here is a pic of the first gen b52s
nickle and dime
