Not too old to learn
As the stock factory tachs seem to get high prices, I wanted to see what you all install that fit in the opening, but are less expensive.
1968 C10 a way to long restoration. |
Re: Non stock tach
I've heard some 80's camaro's will work.
Retired Air Force Veteran
![]() Join Date: Aug 2007
Re: Non stock tach
8door,
Check out this members thread on doing a tach conversion with a Camaro Tach. Said he got the tach on ebay and it was from a '72-'78 but says he has heard anywhere from '70 to '81 will work. Check it out: http://67-72chevytrucks.com/vboard/s...d.php?t=251017 Good Luck
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
Re: Non stock tach
That's good info.
I also just went on ebay and found several listed for Camaros at under a $100 low as $60. And that keeps the overall look the same and is Chevrolet. ![]()
Re: Non stock tach
yep, it sure does. i was gonna go the camaro tach route and then i got lucky at the carlisle spring show in pennsylvania, i found factory gauges with a tach. the bezel was cracked pretty bad. I gave the guy $40.00 cash and walked. I have since rebuilt it and cant wait to put it in my truck. good luck on you tach gauge build.
