never finish start another
WTB: throttle linkage for a 6 cylinder
Needing the crank arm, pivot hinge bolt and throttle cable mount for a 6 banger. I don't need the shift down bracket for the auto trans. Also need the linkage that looks like wire rod in this pic. I am not sure if that is factory or home bent. Any help?
Always on the hunt...
![]() Join Date: Sep 2006
Re: WTB: throttle linkage for a 6 cylinder
I just got in a 71 custom/10 with a 250 I/6 and 4 speed, should have what you are after. Still on the trailer yet, I can try and get you some pics. Mel
Super! let me know what you find. If any one else has somthing please speek up. I will buy from Classic first of course. Not that any one is looking , but I have the non-cable set up if anyone is needing it.
![]() Join Date: Nov 2001
I'm interrested in your none cable set up. Any pic ? Thanks NICK.
This is the rod type linkage. The vicegrips are holding the position. I would have to make a hole approximately 1" to get the pedal rod portion inside the cab. then drill the three screw holes to hold the pedal hinge plate. I can make this work but, would like to stay with the cable type on the newer cab.
Still looking
Ttt
Thanks for the pic's . But I was thinking it was for a automatic set up. Thanks again Nick
Still looking for the cable linkage.
Here are the six cylinder throttle parts I mentioned, these were just removed from a 71 custom/10 with a 250 I-6 & 4-speed. Everything is there except for the short piece that snaps onto the carb ball stud from the pivot link ball stud, truck came in w/o carb and that short link was probably removed with the carb. Throttle cable looks to be oe '71 and does slide in/out nice but it does have a few strands sticking out off each end, still usable as is though. You can have all that is pictured for $40.+ship., if interested pm me your ship to Zip along with an e-mail address and I can send you an invoice thru paypal. Mel
![]() Join Date: Apr 2007
Needle in a haystack is found! Great job & great price Mel! Sharpie
Sold, PM sent.
#13 | |
![]() Pm returned, and an invoice has been sent thru paypal to your e-mail address. |
#14 |
Thanks again Mel. This sight is great thanks to people like you!!!!
