![]() Join Date: Jun 2010
Serpentine conversion
I am considering converting my engine accessories to a serpentine system. What do I need to look out for? Will any year fit my 75 impala 350 motor? I remeber seeing somewhere that a 4.3l 6 cyl has the same brackets. Is that so? I guess I'll have to chanmge out the ps hose fittings due to metric?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
Re: Serpentine conversion
Yes/ the 4.3 carry the same braket . They made a couple different one the most popular is the one from late 89 to 95 and far a s the steering hose difference just unscrew the fitting on the back of you r pump and put iit in the newer one or you can buy an adapter . This swap is high up on my list as well. Jim
I used the one from summit... A little pricey, but everything is clean and new!
Allengator Outta the Blue (my band - available for hire in the DFW area!) 1980 Chevy SWB Pickup (build thread) 1951 Chevy Sedan Delivery 2004 Chevy Tahoe Z71 2011 Harley Davidson Street Glide 2018 Silverado Z71 Crew Cab |
#4 | |
Still plays with trucks
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
"the other guy"
im running one from a 88-92 camaro/bird 5.0/5.7. complete setup can be had for $100. check thirdgen.org classifieds.
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" ![]() |
Did you have any problems with the distance of the fan to the radiator?
Those of you that have converted to serpentine belt, what did you do with the smog pump? Or air pump?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. Last edited by FL71C10; 01-03-2011 at 12:54 AM. |
anyone?
You can buy a smog pump delete pulley.
Posted via Mobile Device |
Thanks, anyone know about the issue of distance to the radiator?
#11 | |
Restoration Virgin!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
That'd be great, thanks. I heard that they don't work as well as the factory clutch fan.
#13 |
Restoration Virgin!
I personally haven't done it, but here are a couple I got from the FAQ thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=216128 http://www.67-72chevytrucks.com/vboa...d.php?t=254617 note that these threads are several years old and pricing may differ a little... It seems from what I've read that a serp conversion and a electric fan setup goes hand in hand?!?!? Hope it helps ![]()
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 01-03-2011 at 10:24 AM. |
#14 | |
I also modified a set of extra serpentine ribbed belt pulleys to fit an older engine with standard rotation accessories & water pump. I just had to drill a new bolt pattern in the water pump pulley and it all lined up. Much better high RPM belt retention than V-belts.
#15 |
"the other guy"
im running dual 12" fans they come on at 195 and click off at 180, fans only run for 37 seconds on average while idling. not bad in my opinion?
