01-02-2011, 02:07 PM | #1 |
Headliner ideas
Any of you guys have any ideas on a homemade headliner? Can't find one @ the pick and pull and don't feel like spending $ 200 on a new one. I know somebody out there has made one from scratch. If only I could flip my cab upside down I would make one out of fiberglass.............
The Fleet........ 68' Camaro - 1st car (restored & still have it) 09' VW Tiguan (Wife's Daily Driver) 14' VW Passat SE TSI (my personal) 14' Ford Edge Sport (Daily Work Vehicle) 73' SWB Stepside - 77K org. miles 74' LWB 454/TH400 - drive train transplant for my (Sold) 98' SWB C1500 W/T - shop truck (Sold) 90' GMC Sierra SLE short step - aka " Jezabelle " (Sold) |
01-02-2011, 02:10 PM | #2 |
Re: Headliner ideas
I always wanted to try and modify one out of a peterbilt or western star into fitting into a square body, then put the matching bucket seats in it
01-02-2011, 02:50 PM | #3 |
Re: Headliner ideas
I am thinking about giving this huys solution from youtube a try.
deadcheap and easy I guess. Some guys from a Dutch forum I visit already confirmed they did their caprice estate like that.
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
01-02-2011, 06:49 PM | #4 |
Re: Headliner ideas
Some genius glued some house carpet to the inside of mine using some nasty glue or construction adhesive. I cant get the glue off without sanding so I guess im just going to clean it up the best I can and do the same thing except with some auto grade carpet and headliner glue. At least it will get rid of the stinky rotten 70s shag carpet.
01-02-2011, 07:11 PM | #5 |
Location: Where I come from, it's cornbread and chicken...
Re: Headliner ideas
I'm not gonna comment on the house carpet padding for insulation or the house carpet, but I will say that you can go to any reputable auto upholstery shop and buy factory headliner from them...then you can scuff up the metal roof with a scotchbrite pad or some 200 grit sand paper and glue the headliner material to the metal roof and install the factory trim back up...noone will notice that the headliner is glued to the metal roof instead of a headliner board...please don't put house materials in your vehicle...for one, they are not fire rated for use in vehicles...
01-02-2011, 07:35 PM | #6 |
Re: Headliner ideas
My 83 has a soft fiberglass insulation type backing - it just slips out of the trim areas, not glued in at all. I took it out and had a local upholstery shop recover it in stock like fabric for $40. I have not seen this type of backing in the catalogs, but it seems like a better idea than cardboard, plastic, etc.
01-02-2011, 07:49 PM | #7 |
Re: Headliner ideas
The fiberglass boards are alot more susceptible to tearing up when you recover it. The new cardboard and abs headliner boards are alot more durable than the fiberglass ones.
Posted via Mobile Device |
01-02-2011, 08:00 PM | #8 | |
Re: Headliner ideas
I knew I should have keep the headline that I pulled out of Blazer!!!!!!!!!!!! I could have modified it to fit. I guess I will be hitting the junkyard next week and see if the 88' Jimmy is still there and take that one. That is after I pick up my smoker from my buddy's house. My youngest's 1st birthday is soon approaching (Jan. 25th) and daddy is trying to smoke a brisket and a couple of rabbitts.............
01-02-2011, 08:04 PM | #9 |
Re: Headliner ideas
Everytime I've looked in LMC Truck or JCWhitney I can't find anything for a crewcab. If it was a regular cab I don't think I'd mind not having one, but I want something in the crew. Right now I have a whitish cottony cloth hanging down all over the place. Not sure where to start to remove it. Dont want to wreck the backing if there is one.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop. |
01-02-2011, 08:11 PM | #10 |
Re: Headliner ideas
[QUOTE=DetroitDan;4383972]Everytime I've looked in LMC Truck or JCWhitney I can't find anything for a crewcab. If it was a regular cab I don't think I'd mind not having one, but I want something in the crew. Right now I have a whitish cottony cloth hanging down all over the place. Not sure where to start to remove it. Dont want to wreck the backing if there is one.[/ QUOTE]
Pull it out and hit it with the fiberglass. Should solve all of your problems and make it stronger to boot........
01-02-2011, 08:17 PM | #11 | |
Re: Headliner ideas
01-02-2011, 08:38 PM | #12 |
Re: Headliner ideas
not sure what you mean. pull what out and hit what with the fiberglass?
01-02-2011, 09:12 PM | #13 |
Re: Headliner ideas
Dan, you need to take the factory headliner trim down around all he sides of the headliner, and the sunvisors, and the dome light. Once everything is down, you should be able to pull the headliner board down easily. Actually the headliner board will probably come down on it's own on your head if you're not careful.
01-02-2011, 09:17 PM | #14 | |
Re: Headliner ideas
On a side note, I'll be breaking ground on my new building for my new business here soon. I was gonna buy a building down the road but Laura and I decided to build instead. That way it'll be setup like I want it to be. I can built it how I want. And it'll be on our property. We have a few acres so it'll be close to home but not too close. The shop will have it's own driveway so hopefully I won't get too much traffic to the house lol. Also hopefully I'll be able to spend more time with my family being it'll be right there. If you have any questions fell free to ask man. I'm here for y'alls questions lol Posted via Mobile Device |
01-02-2011, 09:28 PM | #15 |
6.0 powered square
Re: Headliner ideas
no head liner just a glossy paint roof with head liner trim
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
01-02-2011, 10:48 PM | #16 |
Desert Rat
Re: Headliner ideas
My buddy and I re-covered the cardboard in his Blazer with some black vinyl from the local fabric store. They had "headliner material" there as well, in blue, grey, and tan.
Although we felt a little fruity at the fabric store, it was cheap and easy to do. We laid the vinyl in the sun for a bit, then used headliner spray adhesive to attach it to the cardboard. There were a trillion bubbles at first, but after letting it sit for a while they all disappeared. Its been about 4 months and theres no sagging and the bubbles have not returned. |
01-02-2011, 11:36 PM | #17 |
Still Learning
Re: Headliner ideas
I have done several of these with pretty good success. Find a good backer this one is original fiberglass. You have to scrape all that gummy glue and foam off and get it really clean. I like to use plain old elmers wood glue.
I purchased fabric at a local fabric store that was perfect, I got enough for two headliners for about $12. Here is how we did my son's headliner: |
01-02-2011, 11:47 PM | #18 |
Re: Headliner ideas
Buy headliner material from Jo-ann or Hancock Fabrics etc. Buy Super 77 3M Spray adhesive from Homer Depot. Have fun.
01-02-2011, 11:53 PM | #19 |
Re: Headliner ideas
Mike never seen anyone use Elmer's wood glue for a diy headliner...how long has it been since yall did your son's headliner...I know that the can spray glues never really dry, they just stay tacky and that's why they have a tendency to sag over time...I know the wood glue will actually dry and not stay tacky...the wood glue may actually be the key for do-it-yourselfers to do this successfully...
01-03-2011, 12:28 AM | #20 | ||
Still Learning
Re: Headliner ideas
01-03-2011, 09:29 AM | #21 |
Re: Headliner ideas
You are right about the fiberglass being more delicate to work with. The upholstery guy who redid mine said not to try and remove the remaining bits of fabric that were still adhering to the fiberglass since that might take chunks of fiberglass with it. I guess he built up some glue around those areas and just covered over them. Most of the original headliner had come down on its own, and I had previously picked away some of the loose pieces remaining. Too bad you cannot get a new virgin fiberglass backer - seems like it should be cheaper than the plastic or cardboard ones.
01-03-2011, 09:53 AM | #22 |
Re: Headliner ideas
I just redid my headliner in the 'burb... pulled the old out, and removed the cloth. Then used a wire brush to get as much of the old foam off the cardboard backer, and put the new headliner on with spray on contact adheasive. Looks pretty good. The old cardboard still sags a little, but I am going to make some additional braces, or try and fine some additional factory ones.
04-30-2011, 10:33 PM | #23 |
Re: Headliner ideas
I am trying to figure out what to do with my 82 headliner. The fabric was sagging from the backer, so I pulled it and used the 3m spray adhesive. Within a week the fabric started to sag again. So no luck with the 3m. The wood glues looks like a great idea, but I wonder what will happen with humidity/condensation? I have a unique color fabric (reddish brown) and I am afraid that locating a match will be hard. I might have to hit up a upholstery shop for help on this one. any other ideas out there?
2-66 Chevy C10, 72 Cevy k20 4x4, 82 Chevrolet Silverado Camper Special, 6.2L diesel, 59 Willys Wagon w/57 Chevrolet 283, 69 Camaro SS BB 396/TH350, 77 Camaro (race car project), 87 Camaro (Parts), 1994 Isuzu Rodeo w/87 Camaro TPI 5.7L AX15 5speed/Dana 300................ If its not a chevy, put ain it |
05-01-2011, 03:55 PM | #24 |
Re: Headliner ideas
The way i see it tho, is these trucks look way better with the body colored roof. Looks more like a truck
05-01-2011, 04:07 PM | #25 |
Re: Headliner ideas
just use automotive carpet and glue it to the roof lol thats what i did easy. |
