Old 01-02-2011, 04:19 PM   #1
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
rad support bolting to the frame
I am in the process of swapping out rad supports on my 68'. Can someone please give the order (pictures would be great) of the order of Bolt, Washers, Nuts, etc. t=o secure it to the frame. Thank you, Harry
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 01-02-2011, 04:46 PM   #2
JimKshortstep4x4
Re: rad support bolting to the frame
Here is a picture of the mount that I mocked up. A 7/16-14 carriage head bolt goes through the flat washer with a square hole in it that fits the square under the bolt head. Next the bolt goes through the radiator support, through the upper mount, through the frame support, and through a washer into the sleeve. The bolt and sleeve go into the lower mount and through a washer into the nut.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-02-2011, 05:16 PM   #3
Rack Man
when in doubt....go to LMC
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
