Any tips for installing rear drop springs
Im getting ready to put 4in drop springs under my 68 so im looking for some pointers on what i will be running into?
also is it possible that i can put the rear shock relocators under it without pulling the bed off??
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
Dave's not here, man
Re: Any tips for installing rear drop springs
You will have to grind the rivets off the old shock mounts. I would think the bed would be in the way, but I'm not 100% because my bed was off when I did mine. If all of your rear suspension is original, you may break some bolts talking it all apart. Both the bolts that hold the lower spring cup in place broke when I installed my drop springs. It's a fairly straight forward process. Are you going with an adjustable track bar, too?
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
Mean Green
Yes with a air chisel and torch.
Most likely your factory spring bolts are going to be deeply pitted and rusty. CCP sales a spring cup kit with all new bolts.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel. 60'-1.38 1/4-10.43 MPH-124.6 New ET current 4/2019 AKA MEAN GREEN. |
i have bolts that work (ive had them off before) do i need to support the rear end or anything like that?
Junior Member
I have never done it myself but watched my son.
He jacked up the truck and put jack stands under the frame. Then he put the floor jack under the trailing arm, doing one side at a time.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Shortbed club member
Check that your spring cups are still usable.
Mine crumbled like foil when I took the old springs off. Had to wait til new ones arrived to finish. I installed an ece 4/6 drop with my bed on. Used a drill to remove rivets from upper shock mounts. Just started with a small bit and moved up in size until it fell off.
71 custom/10 6.0/4L80E SWB ece 4/6 72 custom camper 350/3 spd 2020 Chevy Express 3500 2023 Hyundai Tuscon 1986 GMC 3500 Bucket Truck Sent from my Rotary Phone via 14.4kb/s modem. Last edited by Jack_71C10; 01-03-2011 at 03:46 PM. |
most likely you are very safety oriented... but just a reminder.... be safe. safety glasses will save tiny metal shavings from finding the inner workings of your eye.
A buddy and I tackled mine a few months ago and neither of us had any experience with this suspension. We knocked it out in an afternoon; it really is a pretty straight forward process. I hadn't ordered the shock relocaters at that point, so I haven't done those yet. Once I had it all apart, I took all the bolts to the hardware store and bought all new grade 8 bolts and nuts. Cheap and definitely worth the peace of mind knowing you have new hardware. Not much of a tip I suppose, but perhaps just a bit of encouragement before you dive in!
Derek 72 Chevy Cheyenne Super LWB 454 SS LS6 90 GMC Suburban V2500 350 ----------- 64 Chevy El Camino 357 73 Jeep Wagoneer 360 78 Jeep Cherokee 360 79 Scout II 345 88 Jeep Wrangler 4.2L 91 Jeep Wrangler 4.3L 98 Lincoln Mark VIII 4.6L 01 GMC Yukon 5.3L "If it's not broken, fix it 'till it is!" |
I did a 4" drop on my previous truck (68) with the bed on. you will want shock locators. a cut off wheel and a air hammer with a chisle and punch attachment will get the job done.
I totally agree with using new Grade 8 bolts, nuts and washers. Easy to find and worth the minimal cost.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
all new grade 8 bolts, nuts and washers are a must... while i had that much off, and for little money, i replaced trailing arm bushings and u bolts
So its looking like im going to have to take the ol smoke wrench to the upper bolts in my springs sooo what shoud i try not to do? also i have gas lines running along the frame in there area should worry about those LOL
#13 | |
Steve |
#14 |
Grandpa in the rustmobile...
nahh dont worry about the gas lines..HAHA
yeah id becareful or disconnect and let em air out
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#15 |
im super paranoid about setting my truck on fire (done it twice already) so im gunna take the tank out, lines out, everything! let it air out for some time!
#16 |
Big Red - Now its a SWB!
If you plan on taking any of the bolts off with a wrench (instead of torch or grinder), use lots of penetrating oil a few days in advance. I agree swap for new fasteners while you have it apart.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
