Old 01-02-2011, 09:34 PM   #1
Nomadjunkie
Nomadjunkie's Avatar
I thought I have seen everything until now
I was out with a buddy today to look at some parts for his Cuda and they guy had a 58 GMC truck. I was looking it over and when I looked underneath I seen that all his wiring was run inside galvanized pipe and clipped to the inside of the frame. it had heat shrink tube at the end with a bit of black sealer to keep it water tight. He said he has been doing it that way for years and never had a problem. it was bent nicely and looked very clean.
Anyone else ever seen this?
Nomadjunkie is offline   Reply With Quote
Old 01-02-2011, 09:56 PM   #2
71swb4x4
71swb4x4's Avatar
Re: I thought I have seen everything until now
They do that on a lot of trailers if they have open frames instead of the square tubing. It does look very clean but it stinks when there is a short somewhere. You usually have to pull the whole works and start over again. The ones I have seen haven't had sealed ends though and gravel and moisture gets in there which probably promotes corrosion. The way your buddy does it by sealing the ends sounds better.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-02-2011, 10:58 PM   #3
hotrodjoe1952
hotrodjoe1952's Avatar
i have never seen this but thanks for the tip, have been pondering on where to hide wires and now i know lol
hotrodjoe1952 is offline   Reply With Quote
