01-03-2011, 01:32 AM | #1 |
New from N.Texas
Just wanted to say Hello to everyone here Names Sonny.
Ill begin by telling you a few things about myself. Ive been in Law Enforcement for about 13 years now.And have always wanted a C10 swb or Lwb it didnt matter, Ive been after this truck from a family member for 10 years or so. I have finally gotten a chance to get it as it just sits in the yard since he is not able to drive it anymore. 1971 Custom/10 LWB, 3 on the Tree,350,Truck has been converted to disc on the rear/Aftermarket springs. Of course it has its standard wear and tear rocker panels,cab corners and just overall surface rust..Truck has been repainted and the SPID is missing from the glove box so im outta luck on what all options the truck came with...I do know that is was a sort of blue before it was painted white. Truck also has factory A/C and heater both work well except for the valve you have to close or open under the hood to get which ever one you want to run.Seems someone unhooked the a/c heater controls on the inside...Truck runs very good and is mechanically sound. I def do not want to do a swb conversion,I would like to keep this truck close to original as possible except for a static drop and get a inbed tool chest instead of the one it has. (Is this the birthdate of the engine H274..I was told this was original engine? If not would like to know what model i have etc? I can get more pics of the numbers just couldnt find the one on the front side of the eng I have no idea what that is. Anyone? Inside the cab Cab 2 Emblem Engine Bay Rocker Panel both seem to have foam in them. Right Door This is the casting 3970010 it also has a 21 Gm to the left, I havent figured out what that code 21 is for. |
01-03-2011, 01:38 AM | #2 |
N.Texas Project
More pics..
01-03-2011, 01:38 AM | #3 |
Re: New from N.Texas
Welcome Ninevolt. What part of N. Texas you in? I am in Forney, just east of Dallas.
70 SWB 454/TH400 |
01-03-2011, 01:40 AM | #4 |
Sherman/Denison area.
01-03-2011, 01:47 AM | #5 |
Welcome!!! Im just down the street a bit in Austin. You will find the best knowledge and support here... Great bunch of members!
Good luck with your project! |
01-03-2011, 01:53 AM | #6 |
Im definitely looking forward to making this truck my dream truck...First things first get some new rubber..The ones its sitting on now are dry rotted for sitting for so long..
01-03-2011, 04:11 AM | #7 |
Hey Ninevolt ... from Ohio. Ok someone has to say it,,,
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
01-03-2011, 04:12 AM | #8 |
yes welcome!!!!! from cali!
01-03-2011, 07:07 AM | #9 |
cI thought i had posted pics. Ill see if i can fix it after work sorry about that. ok pics are fixed
Posted via Mobile Device Last edited by Ninevolt; 01-03-2011 at 10:58 AM. |
01-03-2011, 11:01 AM | #10 |
Pics should be viewable now had them set to private some how.
Posted via Mobile Device |
01-03-2011, 12:06 PM | #11 |
1965 Chevy C10, 2005 4.8L/4l60
Welcome from Fort Worth (S.)!!!!!!!!!!!!
Nice truck!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
01-03-2011, 01:45 PM | #12 |
Welcome from Kansas. Your engine block casting #3970010 points to either a 1968 327cid 2-bolt main cap engine, or a 1969-79 350cid out of a car truck or vette with 180-370 hp. As far as the date code that would break down to August 27 of 1974. Looks like might have been swapped in the past. You will have to look at the stamping pad for more info. It is located on the front top of the deck on the pass. side, just below the cylinder head. Good luck with the truck! Joseph
1970 Chevelle Nomad station wagon 1966 C-10 lwb,250-six,granny 4speed 1966 C-10 lwb,factory A/C,Custom Cab 1954 Delray 2-door sedan [rat rod project]
01-03-2011, 02:06 PM | #13 |
Glad you finally made it here.
I'm over in McKinney......hope I see you around town! |
01-03-2011, 02:08 PM | #14 |
Howdy from Keller!
Allengator Outta the Blue (my band - available for hire in the DFW area!) 1980 Chevy SWB Pickup (build thread) 1951 Chevy Sedan Delivery 2004 Chevy Tahoe Z71 2011 Harley Davidson Street Glide 2018 Silverado Z71 Crew Cab |
01-03-2011, 03:32 PM | #15 |
Florida Edition
Welcome from Florida! Alot of very smart people in here.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
01-04-2011, 12:20 AM | #16 |
Thanks for the warm welcome...I look forward to being here for a very long time...Im gonna be picking and prodding posts and folks brains here for ideas and help in the near future...
Yeah Sanford66 it seems to be a 350 that was added later bummer. No worries as it is still a good block.Just need to find out what the hp rating was and if its a 2 or 4 bolt main..Ill be getting the head casting numbers and the front eng number behind the alt in a few days...Im still not sure what that thing is on the block by the heads kinds looks like a Transformers symbol lol, any ideas on that???....And any info on the 21 Gm number beside the block casting number as i have not found any info any where for it... Thanks in advance for any help it is much appreciated |
01-04-2011, 12:25 AM | #17 |
Welcome from WV. Great to have you aboard. Nice looking truck
01-04-2011, 12:32 AM | #18 |
sweet nice pics!
01-04-2011, 12:33 AM | #19 |
Yes I fell in love with it 10 years ago. But it couldnt be had then..From there it sat until a few weeks ago when i asked if he would sell it..And to my surprise Im able to aquire it for a very decent price as you can tell if you look close on the sides of the truck someone has rattle canned it in places..Overall it just sat and begin to rust and rot..Im hoping i can fix that and not let it get ruined like ive seen so many others......
01-04-2011, 12:35 AM | #20 |
Another hello from DFW.
01-04-2011, 12:41 AM | #21 |
Does the name imply you have a ws6? I actually sold my 2000 Trans Am to aquire this truck
01-04-2011, 12:54 AM | #22 | |
http://www.ifixsolutions.com/mycar.html
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 01-04-2011 at 12:56 AM. |
01-04-2011, 12:58 AM | #23 |
Always love a good T/A...Very nice looking ex car. I may regret selling mine. I love the truck more though
01-04-2011, 02:43 AM | #24 |
Sonny, i'm not sure about the humps on the back of the block or the 21 number. If you can get the suffix code off of the stamping pad on the front of the block that would give you the best info. By the way the engine you have has 2-bolt main caps. Joseph
01-04-2011, 04:41 AM | #25 |
Welcome from Fort Worth! I'm new here as well and have been sidetracked by a recently acquired Scout II, but hopefully this week my truck can steal some of my attention back!
Derek 72 Chevy Cheyenne Super LWB 454 SS LS6 90 GMC Suburban V2500 350 ----------- 64 Chevy El Camino 357 73 Jeep Wagoneer 360 78 Jeep Cherokee 360 79 Scout II 345 88 Jeep Wrangler 4.2L 91 Jeep Wrangler 4.3L 98 Lincoln Mark VIII 4.6L 01 GMC Yukon 5.3L "If it's not broken, fix it 'till it is!" |
