01-03-2011, 10:12 AM | #1 |
Classic Parts LED tail lights
I recieved a pair of LED tail lights as a x-mas gift. they are from Classic Parts.
I thought i remember reading that you needed a special flasher (or something) for using LED's in tail lights or parking lights. The catalog and the instructions make no mention of using or needing anything extra in the wiring to make them work properly. Can anyone enlighten me? thanks |
01-03-2011, 10:34 AM | #2 |
Re: Classic Parts LED tail lights
Quite often the LED bulbs don't draw enough amps to trigger a standard flasher. That is the reason for changing the flasher. The standard flasher may see it as a bulb being burned out and not work.
01-03-2011, 10:45 AM | #3 |
What flasher do i need?
01-03-2011, 12:08 PM | #4 |
1965 Chevy C10, 2005 4.8L/4l60
I have heard you can put a "load resistor" in line with the LED light, but seems a flasher would be easier and quickly replaceable. I would look on some of the LED light web sites and see what is recommended. They might even sell you one.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
01-03-2011, 12:45 PM | #5 |
Its a Truck Thing......
Show a picture of the LED's, I have the ones from LMC with it being a whole assy and I dont need a special flasher. (So far)
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
01-03-2011, 01:28 PM | #6 |
You don't need a special flasher if you're still running the original 1157 bulbs in the front turn signals, they will put enough load for the old style of flasher to work. If you're also running LEDs in the front, then you would need an electronic flasher.
01-03-2011, 01:33 PM | #7 |
When I put my L.E.D.s in it would blink, But it was very slow.
An electronic flasher from the local parts house fixed it for about 8 bucks.
The TEAL GMC build thread is HERE 1972 GMC SWB 454 oval ports TH400 fastest 1/4 mile time so far 13.05 @ 104 If you think you have too much horsepower you obviously have a traction problem ! |
01-03-2011, 03:51 PM | #8 |
I'll get a pic later.
I installed them and took it for a drive. i did notice the lights flashed slower. several times i noticed the drivers side turn signal indicator go green even though i wasnt using the blinker. It would go out and then come back on, only to go back out. Does this mean i need a special flasher? Why would it make the turn signal indicator light up like a bulb was blown? |
01-04-2011, 05:02 AM | #9 |
When I added LED rears, they worked fine with the flasher that was already in there. This was also true on my Jeep when I added the trailer-style LEDs in the rear corner guards. I think the combination of the other lights on the circuit is sometimes enough to show the flasher the load wants to see, but often time the flasher will indeed have to be replaced, maybe a case by case type thing. I would imagine that long lengths of old wiring (to the tail lights as well to the front) also contribute to the necessary load. The ones I added to my 72 were the ones that just plug into the original light socket, no wiring required. I'd say toss 'em in and see what happens, maybe it will be good to go with your stock flasher.
Derek 72 Chevy Cheyenne Super LWB 454 SS LS6 90 GMC Suburban V2500 350 ----------- 64 Chevy El Camino 357 73 Jeep Wagoneer 360 78 Jeep Cherokee 360 79 Scout II 345 88 Jeep Wrangler 4.2L 91 Jeep Wrangler 4.3L 98 Lincoln Mark VIII 4.6L 01 GMC Yukon 5.3L "If it's not broken, fix it 'till it is!" |
07-15-2011, 01:58 PM | #10 | |
07-15-2011, 05:15 PM | #11 |
i recently got a set from ECE and it called for a electronic flasher in order for it to work right..cant wait to try them out
