Old 01-03-2011, 11:23 AM   #1
mikewarme
HELP! Need door pictures
Ok guys im stuck........ I put my door together and here is the result. The vent window is the original part just with new rubber I installed. I know the outter scrapper is too long. Thats a start. But notice how the scaper does not touch the glass next to the vent. It looks great at the other side where it starts, and than it wanders away.
So, could someone please take a pic of this area on a driver side door?
Also the vent rubber does not contact the door. Shouldn't it?
Is the door tweaked up there?
I'm sure I am not the only one who has had this issue.
Any help would be appreciated!
mikewarme is offline   Reply With Quote
Old 01-03-2011, 11:39 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: HELP! Need door pictures
I would say that the door is spread apart in that area. You don't say what year your truck is but it's a common problem with the earlier trucks. In '72 they put a screw through the door on the inside to hold them together. When you had the door apart did you notice whether the metal web in that area was cracked or broken? (It is like a metal strap that holds the inner and outer door in place)
LockDoc
Leon
Old 01-03-2011, 11:41 AM   #3
mikewarme
I was thinking the same thing! Except the strap was not broke. I better take it apart again and be sure. But was the screw on the 72 going all the way through? Or did it just attach to the vent window?
Mike
Old 01-03-2011, 11:45 AM   #4
LockDoc
LockDoc's Avatar
I added to my last post. I have never investigated the '72 setup but I would suspect that there was a tab welded on the inside of the outer door skin that the screw went into. It's a pretty long screw.
LockDoc
Leon
Old 01-03-2011, 11:49 AM   #5
Indyuke
Ditto to above posts. Mine is the same way. To make it better, I cut the rubber so it goes around the vent post. It probably lets in more water at that specific point because of the missing rubber, but helps keep water from running down the window and into the door by allowing the entire strip to sit a little closer to the window.
Indyuke is offline   Reply With Quote
Old 01-04-2011, 10:05 AM   #6
mikewarme
Great pic in the ice! Anybody have a pic of a door without this problem?
How about a detail pic of the 72 door setup with the screw?
Old 01-04-2011, 10:23 AM   #7
srvivor71
srvivor71's Avatar
A nice little bead of black silicone caulk at the vent post will seal that up nice and neat. If you can't locate black silicone, try a glass shop. They will usually have it in stock.
srvivor71 is offline   Reply With Quote
Old 01-04-2011, 01:49 PM   #8
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Use an automotive window sealer if you want to seal that area. You want to stay clear away from silicone. Silicone atracts moisture causing rust under it, and also gives the metal what they call Silicone invasion. Near impossible to get rid of and will always cause problems with future painting. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 01-07-2011, 10:14 AM   #9
mikewarme
Well guys.... I really would like to make it look tight like the factory. I guess there aren't to many 72's on here right now where I could get a pic of how the screw attaches inside. I know im missing the dimple in my door for it, but I think I have an idea to fix it. I will investigate this weekend and report back.
