01-03-2011, 01:17 PM | #1 |
Water Leak Question
I have a 71 GMC C20, when it rains I have water coming into the truck(carpet is very wet) on the drivers and passenger floorboards, closest to the sides. NO holes in floors.
Possibly coming in through the side vents or ?? Anyone know how to fix this? It leaks with the vents open and closed.
Current stable: 1970 K5 Blazer 4x4 1972 K5 Blazer 4x4 SOLD: 1971 GMC Sierra Grande 2500 2wd 1972 Chevrolet K5 Blazer 1966 Chevrolet C20 1972 Chevy Suburban 4x4 1500 1956 Chevy 150 2 door post 1956 Chevy 2 door post bel air 1968 Chevrolet C20 1958 Ford Thunderbird 1968 4x4 Suburban 1/2 ton |
01-03-2011, 01:22 PM | #2 |
Re: Water Leak Question
if sealant in drip rails is dry and cracked the rain water goes in and down the roof pillars down thru vents
01-03-2011, 01:43 PM | #3 |
above the dash in the wipers area there are some body seam that could be rusting through and lealing mine were.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
01-03-2011, 03:13 PM | #4 |
Grandpa in the rustmobile...
behind glovebox i have a big rusted out hole, thats wehre mine comes from
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
01-03-2011, 03:42 PM | #5 |
What?
Has the windshield been replaced, and the weatherstrip as well?
In my Suburban, the rubber seal doesn't seal to the glass very well on the driver side. It's like the channel that the glass sits in is to wide for the glass, and I get water pooled up on my dash and drips down the kick panel and makes the carpet wet.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
01-03-2011, 03:50 PM | #6 |
I dont have any holes in the firewall or the channel on the firewall.
I'm guessing its the seal on the drip rail or the windshield, however the top of the dash is never wet. Best solution to fix the drip rail channel? Silicone?
01-03-2011, 03:55 PM | #7 |
The Older Generation
I wouldn't. 3M has a product just for that purpose. I added a picture of where mine was leaking at the lower windshield seam. I cleaned all of the seams out and re-caulked them. It can also leak in at the antenna cable if it is not sealed good. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-03-2011 at 04:03 PM. |
01-05-2011, 12:31 PM | #8 |
Thank you to all. I will wait for it to dry out here a little, been raining so much, and try your advice.
01-05-2011, 01:05 PM | #9 |
How many trucks in Cali, do you think, are sprouting leaks these days?!?
01-05-2011, 11:27 PM | #10 |
Mine leaked real bad just like you described in the floor too. I cleaned the channel on top of the cab and used brush on seam sealer (also available in tubes like caulking)in the channel. I also brushed it inside the cowl area at the front all the way across .It rained all day today and for the first time since I bought this truck a year a go it did not leak.
