![]() Join Date: Jan 2009
Factory Cruise Control! Need Pics
Hello guys and Happy New Year! I have been coming on here for a couple of years now but I still feel like I am new to the forum. I have several projects going, but one on the back burner that I want to pull back out is my Cheyenne. It is a well options truck, but my plan with it is to Max out the options. I am almost there! It has Tilt, tac, 402BB, Posi, Cheyenne Super option, and I have picked up some correct buckets seat with a console that I have to rework. My question today is what is the correct cruise control setup on these trucks. What did they look like and how did they hook up? I have researched this on here but about all I have come up with is a few pics of truck on the forum. Is the control button surposed to be on the dash or is it in the turn signal lever? Which is correct or could both be correct? What year did cruise come out on our trucks? Was it on any SPID lables? I would like to see Pics of this rare option! How it is hooked up under the hood especially the 402BB setup on the carb. Did it only come as a dealer install option or did it come strait from the factory or both? I have been collecting parts but not sure if what I have is correct! Would like to see lots of pics! Thanks for any help! Krash!
Re: Factory Cruise Control! Need Pics
I believe it was a dealer install option on the 71 and 72 model years but was available as a factory option on some of the earlier years. My truck had what most consider the 73 up dealer install cruise. I am confident it was installed at the dealer when my truck was purchased new. I have no doubt that the 73 style cruise was at the dealers while there was still some of the 72 year model trucks on the lot. I'd be happy to take pics of what is there but mine is a small block and you have probably already seen them in your research here. I'll be watching to see what others have to say as this seems to come up every so often. Nice truck BTW.
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 01-03-2011 at 01:57 PM. |
I would really like to see any pics you have weigthter or not it is a BB or SB! I am also looking to find somebody or some place who rebuild these units or parts kit to rework the unit myself? What you said about some being installed in early 1973 makes since. I think the cruises installed as a factor option and not a dealer option had the control on the dash? The 1973 and later had the control on the turn signal, which is what I have. I am just guessing and I could be wrong! Thanks!
![]() Join Date: Nov 2010
Hey KrashMan454, I took a few pictures of a Speedostat cruise control unit on my truck, made by Perfect Circle/ Dana Corp., hope these help
My SPID doesn`t mention cruise control, and I don`t have receipts to show where or when it was installed.
Florida Edition
![]() ![]() Join Date: Oct 2010
I believe this is dealer installed on my 72 Custom Camper. The control mod is under the dash in the cab (Dana Corp) and the control is on the turn signal lever. Hope this helps a little.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
I was looking in the FAQ index and found this! But would still like Pics of what everyone is running! http://67-72chevytrucks.com/vboard/s...?t=136867nyone is running on there truck!
here are some. I think this is 67-70 but could be 71 72 as well. not too sure.
#10 | |
![]() ![]() ![]() Several good pics in this thread of the carb end bracket on my truck http://67-72chevytrucks.com/vboard/s...d.php?t=378412 This is a good thread about the cruise option. http://67-72chevytrucks.com/vboard/s...d.php?t=378514 |
![]() Join Date: May 2006
I've got the factory instructions if you need copies
Roger Koop is a good guy to buy parts from, bought my '72 set up from him
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
Thanks Jaros44sr! I sure could use a copy of the instructions!
#13 |
give me a little while to figure out how to use my scanner, and I will mail them out to you. Keep PMing me to remind me
#14 |
OK, found the copy of the installation instructions. PM me your home addy and I will get them off to you asap
#15 | |
Would you mind sending me a copy as well i cant seem to find mine. Also is Roger Koop on the board? Im trying to find a 68-70 cruise turn signal switch. Thanks Bryce |
#16 |
Sure, just let get to a computer for more info.or pm me home addy
#17 |
PM sent
#18 | |
What are the differances between the two switch levers???
#19 |
Wide n'Low
![]() Join Date: Jan 2007
I have a copy for both the 69-70 and the 71-72 posted online in pdf format. Feel free to download a copy.
http://www.2heeldrive.com/Chevrolet/...ise%20Control/
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
#20 |
HOARDING SPECIALIST
![]() Join Date: Sep 2009
i am parting a 70 custom camper and it has factory cruise that is listed on the spid
NEW PROJECT 67 C/10 SHORT FLEET |
#21 |
Wide n'Low
Can you list what the code is on your SPID for the cruise, I know someone besides me was looking for it,
#22 |
HOARDING SPECIALIST
yes i will dig the glovebox out and post a pic
#23 |
just got the copies made...sorry for the delay
#24 |
Jaros44sr the instructions came in today!!! Thanks for taking the time to find them and mail them to me! That is what I like about this forum. Great people alway willing to help! Thanks
#25 |
Anyone have a copy of the dealer installed cruise setup, 72 era?
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
