Old 01-03-2011, 07:27 PM   #1
bosco200
bosco200's Avatar
Lower and Upper Trim
Alright I got a question for you guys....I don't have the money to buy brand new trim....how hard do you think it would be to clean up some trim and repaint them....do you think they would turn out decent...cuz my truck is black and I need some more chrome and trim to break up the black....Thanks in Advance
bosco200 is offline   Reply With Quote
Old 01-03-2011, 08:57 PM   #2
bosco200
bosco200's Avatar
Re: Lower and Upper Trim
Bump...cmon i know Someone know.
Old 01-03-2011, 10:01 PM   #3
Gene
Gene's Avatar
Yep, i've painted the black part myself. If you want the woodgrain look, the woodgrain tape is pretty inexpensive and looks great. You can remove small and large dings with a hammer and dolly.
Gene is offline   Reply With Quote
Old 01-03-2011, 10:09 PM   #4
bosco200
bosco200's Avatar
Thanks...do you know a way to get the trim off without bending it?
Old 01-03-2011, 10:12 PM   #5
DT1
DT1's Avatar
I assume you're talking about the upper and lower molding. You can repair it yourself but it takes a whole lot of time and patience.
Here is a before and after shot of mine. I used a screen door roller to remove the big dents and a sander to smooth them out. After that, I used a buffing wheel to restore the shine. You can have them re-anodized but a less expensive alternative is to coat the bare aluminum with a good grade of automotive clear coat.
Before...
After...
DT1 is offline   Reply With Quote
Old 01-03-2011, 10:31 PM   #6
71stub
71stub's Avatar
I think it also depends on your skill and what you start out with for trim.
1971 Cheyenne Short Fleet - 468BB/TH400, Tilt, Tach, PS, PB
1967 Custom Short Fleet - 327/4spd
71stub is offline   Reply With Quote
Old 01-04-2011, 07:49 AM   #7
Gene
Gene's Avatar
DT1 your trim looks awesome, making me re-think buying new!
Old 01-04-2011, 10:42 AM   #8
gcburdic
Restoration Virgin!
gcburdic's Avatar
bosco200...Eastwood sells a anodize remover that's safe and easy to use....http://www.eastwood.com/ew-anodize-remover-gal.html....
use this, bump out the dings, then a stepped (200, 400, 600, 800, 1200, 1500, 2000) wet sandpaper on each then finish off on a buffing wheel and hit it with clear coat or wax to save the finish....it is very time consuming, but costs less and gives you some great results as shown above
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 01-04-2011, 06:46 PM   #9
bosco200
bosco200's Avatar
Thanks guys...and that trim looks awesome.
Old 01-04-2011, 06:58 PM   #10
RED67
Forever Grateful
RED67's Avatar
DT1.....U did one HELL of ya job on that trim....like you said time and patience..NICE
R.I.P Dad 04-07-42 - 05-27-09
RED67 is offline   Reply With Quote
