Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 01-03-2011, 09:50 PM   #1
team39763
Where can I buy the complete fuel lines for a 95 Sonoma?
I took the bed off my 95 Sonoma and dropped the tank. I can't tell if the tank is bad since it's got that plastic baffling in the bottom. The lines are full of rust and crap though. They don't look rusty from the outside, just full of rust on the inside. I figure I should replace them and possibly replace the fuel tank. Where can I get the complete lines? Can I use a cheap replacement tank(Napa, Autozone, etc)? My biggest concern is the lines though. I'd appreciate any advice. Thanks.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 01-03-2011, 10:28 PM   #2
BarryB
BarryB's Avatar
Re: Where can I buy the complete fuel lines for a 95 Sonoma?
You might check with LMC, other than there its either a boneyard or the dealer. Thats where I would look. Maybe somebody else will chime in with more info.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 01-03-2011, 10:42 PM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Check with www.rockauto.com or www.jcwhitney.com for fuel tank replacements. Rockauto should have the replacement lines.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 01-05-2011, 09:10 PM   #4
team39763
Thanks guys, I'll check those places.
Old 01-07-2011, 01:34 PM   #5
team39763
Well, I looked a little closer at the lines and they aren't actually rusted, they are just full of rust/crap from the tank. I do see little rust spots developing on the bottom of the tank. So I'm buying a new tank. I'm gonna see if I can clean these lines out though. Any suggestions? My plan is to use carb cleaner and compressed air and maybe some oil.
Old 01-07-2011, 05:16 PM   #6
BarryB
BarryB's Avatar
Yeah that is a good way to to it. Try just blowing air thru at first, hopfully that will blow out most of the gunk. Then follow up with the carb cleaner. Oil isn't really needed so I would say skip that step. air and carb cleaner should be good enough.
Two rules in life.
