Old 01-03-2011, 10:11 PM   #1
nikwho
nikwho's Avatar
problem with brakes '83 K10 14bff
Sorry for the double post mods, can you delete the other post in the 73-87 section. I was not getting any responses there.
I have an '83 K10 with 3/4 ton axles swapped under it. Its got a corporate 10 bolt in the front and a 14 bolt full floater in the rear w/ drum brakes. I was told that the axles were from a "comparable year" 3/4 ton truck. Truck was as is when I bought it. I am assuming that it has the stock K10 proportioning valve. My problem is that my rear brakes will lock up very easily with what feels like very little if no braking to the front. has, a couple of times, stalled the engine while braking in gear traveling at 20-30mph. Even with just the slightest push of the brake pedal. Makes for some interesting driving characteristics! Its a nightmare(ok, sometimes kind of fun) in the snow! Any thoughts? I was thinking that maybe its a proportioning valve issue. Thanks for the help guys
Nik
'59 Apache - 383" SBC/TH-350
'68 GMC - BBC/TH400
nikwho is offline   Reply With Quote
Old 01-03-2011, 10:25 PM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: problem with brakes '83 K10 14bff
Forgive with starting with the basics. Have you adjusted the rear brakes? Also is there any oil leaking into the drums?
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 01-03-2011, 10:27 PM   #3
nikwho
nikwho's Avatar
no problem. sometimes I skip the most basic steps. Yes, they have been adjusted. I will need to pull them apart to see if there is any oil leaking into the drums. I will start with that and report back. Thank you
'68 GMC - BBC/TH400
Old 01-05-2011, 02:08 PM   #4
cur88alan
i would make sure they havent been adjusted to much did that once had the same problem i would try releasing them a few clicks and see what happens
cur88alan is offline   Reply With Quote
Old 01-05-2011, 09:27 PM   #5
Chevy1TonFun
Grease Monkey
I would try backing the brakes off first before pulling the drums. 3/4 ton axles are a pain in the a$$ to pull drums.
Old 01-05-2011, 09:45 PM   #6
Blue Chevy 1987
Blue Chevy 1987's Avatar
yea sounds to me like they are adjusteed too tight or have oil leaking in drums. im running your exact set up but i converted to rear disc. i have no problems stopping. no upgraded master cylinder or valve. also check an make sure you dont have a vacuum leak specially around the brake booster
Blue Chevy 1987 is offline   Reply With Quote
Old 01-06-2011, 10:53 AM   #7
Full floating rears have a tendency to leak from the seals on the back of the drum which makes the brakes grab bad. They can stick when the e-brake is left on. You mostly notice this when it's wet outside.
