Old 01-03-2011, 10:41 PM   #1
cjohnson6772
cjohnson6772's Avatar
1972 Gas tank vent problem?!?!?!?
Ok so I have a 1972 Cheyenne Super and ofcourse my truck came with the one year only tank with the emissions nonsense and the carbon canister stuff. installed a tuned port injection set up on my truck and ofcourse did away with the carbon canister. I removed the hard line loop from the passenger side of the cab and put a rubber cap over the tank fitting. I don't think my cap is vented because now I am getting a lot of pressure buildup and the tank is being sucked in until I relieve pressure by opening the cap. How cap I fix this without installing a new tank and without having a gas smell in the cab? Reinstall the hard line loop and leave it open underneath the cab? Can I get a vented cap? Is my '72 cap vented? Thanks for any help.
cjohnson6772 is offline   Reply With Quote
Old 01-03-2011, 10:48 PM   #2
jondancer
Re: 1972 Gas tank vent problem?!?!?!?
could you install a vented cap? i'd also like to know
jondancer is offline   Reply With Quote
Old 01-03-2011, 11:02 PM   #3
justincat
balkcamp vented cap 703-1220 from napa will work(i have heard). It also seems like running the other line outside of the cap would be a great ideal, but i have never tried it
justincat is offline   Reply With Quote
Old 01-03-2011, 11:11 PM   #4
MT1972cheyenne
MT1972cheyenne's Avatar
I left the hard line loop up in the cab, and let that vent out beneath the cab. It worked great.
MT1972cheyenne is offline   Reply With Quote
Old 01-04-2011, 10:06 AM   #5
cdowns
cdowns's Avatar
that's the way i've always done it safe and simple. i did run the vent hose back a few feet in back of the cab so not to get fumes in cab
Old 01-04-2011, 09:18 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
get a cap for a 69. You can get it at autozone or anywhere else. May as well get 2 though, the rubber only lasts a couple years at best. I had one leaking down the side of the truck in less than a week.
Craptastic at best. (but is IS pretty chrome)
Old 01-04-2011, 09:24 AM   #7
trucks72
trucks72
trucks72's Avatar
The 69 cap will not work. I think the catches are too short.
trucks72 is offline   Reply With Quote
