Old 01-04-2011, 12:13 AM   #1
89muscletruck
89muscletruck's Avatar
96 vortec wont start
Hi, my dad's 96 1/2 ton Z71 with 5.7L vortec will not start. And he is looking for opinions on what to look for to try to get it running again.
Apparently one day when he went to drive home from work it just would not start up again, it had been running fine that mourning.
He had thought that it was one of the ignition modules, the one that sits just under the dizzy, he replaced that but still nothing.
I haven't had a chance to personally go a look at it yet, I am going to do this tomorrow, and we thought we would ask you guys to share your wisdom on what the problem might be.
I don't know as much about the problems of the Vortec as most of my experience has been with the TBI's, so any help will be greatly appreciated.
89muscletruck is offline   Reply With Quote
Old 01-04-2011, 01:09 AM   #2
SwampDonkey
SwampDonkey's Avatar
Re: 96 vortec wont start
when you turn the key can you hear the fuel pump kick on? my buddys vortec fuel pump randomly quit a few times
1993 GMC Sierra 350/4l60 "The Gray Ghost" http://67-72chevytrucks.com/vboard/s...d.php?t=365337
NEW!
1989 Camaro, 2.8 For Now...
1988 Chevy Cheyenne 305/th400 "Bad Majik" (project) SOLD! http://67-72chevytrucks.com/vboard/s...76#post4139076
SwampDonkey is offline   Reply With Quote
Old 01-04-2011, 08:31 AM   #3
BigBlocksRule
^ actually a pretty common problem.
Sometimes you can whack the gas tank right in the middle and get the pump to run again for a few minutes.
After it's sat a while and had time to bleed pressure down, put your ear directly against the side of the truck by the tank and listen when someone else turns the key "on" for you. Don't try to start it, just the key "on" and listen to hear the pump.
When it's time to replace it, loosen the bolts on the passenger side to the point where they only have a couple of threads engaged. Pull 'em all out of the driver's side, then tilt the bed up to gain access to the tank. This is a whole lot easier than dropping a dang tank.
BigBlocksRule is offline   Reply With Quote
Old 01-04-2011, 04:45 PM   #4
89muscletruck
I believe that the fuel pump is working.
Old 01-04-2011, 07:19 PM   #5
speedygonzales
speedygonzales's Avatar
If it was running that morning and quit in the afternoon it's likely the fuel pump
Fuel pump more than likely. Relieve the pressure at the schrader valve on the fuel rail. Then cycle power 5 or 6 times on and off about 3 seconds each. The hit the schrader valve again to see if there is any pressure. If pressure is at the prescribed 60PSI minimum it should spray like a fire hose.
If pressure checks out, go to the cap and rotor.
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 01-04-2011, 10:05 PM   #6
ChevyTech
Put a fuel pressure gauge on it and see what the fuel pressure gets up to during the 2 second prime cycle with the key on and engine off.
Then watch the pressure and see how much and how fast the pressure falls after the fuel pump stops.
Let us know what you find.
A 96-up Vortec engine should have 60-66 psi. Key on/engine off = book spec 60-66 PSI
Engine running = 58+, pressure should increase when you blip the throttle
Old 01-04-2011, 11:26 PM   #7
chevyndn
i know this sounds crazy, it did to me to, but change the battery terminals. my 98 gmc sat for a month because it wouldnt start. i tried jumping it, changed fuel pumps and all sorts of other things to. i talked to a buddy who had a 99 burb and told me to try that. i looked at him like he was stupid to my disbelife it started when i changed the screws on the terminals. i would try that first they only like 5 bucks to change. i know it sounds crazy but try it.
chevyndn is offline   Reply With Quote
Old 01-05-2011, 12:06 AM   #8
bwood
bwood's Avatar
The module he changed is not for the ignition, it was a camshaft position sensor and it will not keep the truck from starting.
Checking the fuel pump as everyone has stated is step #1. The suggestion to check the battery connections also is a good one. These trucks use stacked positive cables and are prone to corrosion between them. The one farthest from the battery powers everything in the truck except the starter, a poor connection can cause a host of PITA issue.
2013 Ford F150 FX4
2006 Chevy Silverado 1500
1982 Chevy C1500
2020 Ford Explorer Limited
2008 Ford Escape
bwood is offline   Reply With Quote
Old 01-10-2011, 11:47 PM   #9
89muscletruck
thanks for the replies guys.
Sorry I didn't reply sooner but I have been busy with getting ready for the winter semester. I will pass the info on to Dad, but it may be till the spring melt till he or I get a chance to look at the truck again. As it is sitting in a snowdrift by the grain bins, and I am 2 hours away at university.
Old 01-11-2011, 10:05 PM   #10
bwood
bwood's Avatar
Also make sure the crankshaft position sensor is plugged in at the timing cover.
2013 Ford F150 FX4
1982 Chevy C1500
2008 Ford Escape
Old 01-12-2011, 06:44 PM   #11
speedygonzales
crank sensor won't keep it from starting either.
Pride and joy
Old 03-28-2011, 10:32 PM   #12
89muscletruck
update:
Dad has been working on it, but it still won't start here is the rundown
It has spark and it turns four times before it sparks again, fuel pump starts and then shuts down once it has pressurized the system, but it seems to have a weak spark, its not too bright.
Any ideas on why it won't catch?
Old 03-28-2011, 11:12 PM   #13
Boog
laying low
Boog's Avatar
The engine will not startup with low pressure even though the pump cycles on and off. You gotta get that fuel pressure number.
Boog
Old 03-29-2011, 09:56 AM   #14
big_ac2001
Originally Posted by 89muscletruck View Post
update:
My '96 had the same problem a while back. The truck would not start and it had a very weak spark. I changed the distributor cap and rotor and it started and has been running good ever since. Take the cap off and see if there is any corrosion in it or on the rotor.
'71 Custom 10 lwb, 327ci, TH350
'49 chevy 3100 5 window truck. 235 six cylinder. 3 speed on the column.
big_ac2001 is offline   Reply With Quote
Old 03-29-2011, 05:30 PM   #15
spudz
spudz's Avatar
YES IT WILL.... Just about the only thing that goes wrong with these trucks that make em not run in the most common order are:...... fuel pump, crank sensor, and ignition module that located on a bracket on the passenger side of the intake with a little aluminum heat sink under it. OR the distributer caps are bad about shorting internaly. You need to A: check and verify your fuel pressure. If no guage, spray some starter fluid into intake and see if it trys to start.. If it does, then fuel is your problem.. If nothing then you are going to need a scanner and diagnostic flow chart to correctly diagnose it without just throwing parts at it.... BTW... it will spin a few times before each cyl will spark. If you are looking for a contant spart check it at the coil...
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 09-30-2012, 09:54 PM   #16
Jaybird74
Jaybird74's Avatar
I know this is an older thread but I'm having same problem I think, Quick rundown....
Stopped for fuel the other night, everything was fine till then. After pumping gas wouldn't start, ended up having it towed to my house. Checked all fuses, replaced fuel filter, then pump, it will start if I dump a bit of fuel into throttle body but have no pressure at all, pump is not engaging at all. I'm at a loss
www.jayboland.com
Jaybird74 is offline   Reply With Quote
Old 10-01-2012, 12:49 AM   #17
BarryB
BarryB's Avatar
If you replaced pump. You should double check all the connections going to the pump. have you checked the fuel pump relay?
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 10-01-2012, 07:01 AM   #18
Jaybird74
Jaybird74's Avatar
Yea I checked all connections, probably gonna pull it and double check wires in tank after I take a volt meter to it
www.jayboland.com
Old 10-02-2012, 02:29 AM   #19
Jaybird74
Jaybird74's Avatar
Was pigtail in tank, fixed!!!
www.jayboland.com
Old 01-12-2016, 06:20 PM   #20
Ricky381974
I've working on a 98 Chevy z71 new fuel pump crank senser cam senser ignition module new coil new pcm new ecm new cap and rotor fuel pump pumps up 55 psi no fire out of the coil still
Ricky381974 is offline   Reply With Quote
Old 01-12-2016, 07:37 PM   #21
BigBlocksRule
Check wiring ground near the thermostat and is the engine grounding strap hooked up?
Old 01-12-2016, 11:25 PM   #22
Ricky381974
All three grounds are hooked up the one on the back of passage side of head black with white stripe the one by lower left by the crank senser and the one by the thermostat
Old 01-13-2016, 10:10 AM   #23
speedygonzales
Start a new thread instead of bringing back a 5 year old one
Pride and joy
Old 01-13-2016, 09:21 PM   #24
Ricky381974
Up date put new ignition switch pass lock module. No go test the white wire ignition module to the computer and key off no voltage key on 0.06 volts start jumps to 0.46 volts my other running truck no voltage key on and start
