Old 01-04-2011, 07:10 AM   #1
MistaGavin
MistaGavin's Avatar
Dash Lights
Hey, how many dash lights are in one of these trucks that illuminate the gauges? I need to order some smd leds before I open it up. Truck's a 1970 CST
MistaGavin is offline   Reply With Quote
Old 01-04-2011, 07:19 AM   #2
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Re: Dash Lights
do you have a 3 gauge bezel or a 7 gauge bezel?
My 7 gauge bezel has 9 bulbs not sure about the 3 gauge bezel. Someone should chime in on this
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 01-04-2011, 09:07 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Dash Lights
it may have 9 bulbs, but only 4 of them light the guages.
Old 01-04-2011, 09:22 AM   #4
myoldchevytruck
Re: Dash Lights
Exactly. Thanks Andy.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 01-04-2011, 03:03 PM   #5
MistaGavin
MistaGavin's Avatar
Re: Dash Lights
Yeah it's a 7 gauge bezel. So only 4 bulbs light it? Thanks guys
Old 01-04-2011, 03:21 PM   #6
myoldchevytruck
Re: Dash Lights
yep, 4 light the gauges.
In the pic, the red circles are for the guages and the green are for the turn signals
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 01-04-2011, 06:50 PM   #7
69C-owner
Re: Dash Lights
what do the other 3 do?
http://67-72chevytrucks.com/vboard/s...d.php?t=43855069 LWB Fleet
1994 Buick Roadmaster
1994 GMC Sonoma
69C-owner is offline   Reply With Quote
Old 01-04-2011, 07:13 PM   #8
fixit-p
fixit-p's Avatar
Re: Dash Lights
High beam, Brake warning and alt light
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 01-04-2011, 07:30 PM   #9
TallGMC
Re: Dash Lights
Hey Guys,
I've never pulled off the dash before to access the guages. Is there anything I need to know before I do it? Any tricks or things not to do. I assume its just the screws in the front and pulling off the lights and washer knobs correct?
TallGMC is offline   Reply With Quote
Old 01-04-2011, 07:39 PM   #10
burkeens
Re: Dash Lights
Thanks for the thread. I have the same question and issue.
burkeens is offline   Reply With Quote
Old 01-04-2011, 08:02 PM   #11
Cole Trickle
C-10 Club Member
Cole Trickle's Avatar
Re: Dash Lights
Where do you get the LED's are they plug and play?
IU have had a new bezel for several months and the old one dosent want to come off. I was told you need to drop the colum. (There is also a trick for getting the light know to pull out if you do a search)
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels
1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold
Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910
Cole Trickle is offline   Reply With Quote
Old 01-04-2011, 08:44 PM   #12
JAB'70
Re: Dash Lights
As far as removing the bezel. Yes, drop the column and you should be able to slide it out. To pull the light switch knob, slide your hand up inside the dash behind the bezel, moving up to the light switch you should feel a "spring clamp" holding the knob in place (easier if you push the switch in and out to help locate the back of it). Squeeze clamp with one hand and pull the knob out with the other... Hopefully you understand what I've just tried to explain.
CWO3, USN, RET
When a man's ways please the Lord, He makes even his enemies to be at peace
with him.; A man's heart plans his way, But the Lord direct his steps." (Prov
16:7, 9 NKJV)
Never look down on anyone unless you are helping them up. SMS.
JAB'70 is offline   Reply With Quote
