Old 01-04-2011, 01:33 PM   #1
dfosh
Changing window channel
I am changing all the window channel felts and wipers . Do you have to remove the vent window assembley to do this ? How do you replace the channel behind the division bar? can someone explain the process for this ? Thanks for any help .
dfosh is offline   Reply With Quote
Old 01-04-2011, 02:15 PM   #2
Sammy
Re: Changing window channel
You are going to have to gut the door of the window glass and the vent assy to get at the channel and felt. Then install the inside felt strip the vent assy and window. Lastly install the outer strip. The channel bar will unbolt once you remove the window you can get it out. Easier for me to work on the door laying flat on a table but many have no problem doing this with the door installed. Gravity and working in the dark kick my patience pretty hard.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
