Old 01-04-2011, 01:34 PM   #1
70short
Gear ratio
Someone on craigslist has a rear end for sale. How do I tell what the gear ratio is if there is no markings? How many turns of the axle compared to the shaft input? I am looking for 3.73's.
Gary
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 01-04-2011, 02:04 PM   #2
swamp rat
swamp rat's Avatar
Re: Gear ratio
Approx 3 3/4 turns of the pinion to one turn of the axle.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-04-2011, 02:06 PM   #3
70short
Re: Gear ratio
What is it with the 3.08's for comparison? That is the 4 speed truck gear ratio right?(3.08).
Edel 600 cfm carb
HEI
shorty Headers
4/2 Drop
"CHEVY RULES"
Old 01-04-2011, 03:18 PM   #4
cdowns
cdowns's Avatar
Re: Gear ratio
buying a 40 year old rear end i'd want to look at the gears to see condition// the numbers are stamped on the gears
Old 01-04-2011, 08:08 PM   #5
swamp rat
swamp rat's Avatar
Re: Gear ratio
Just a smidge over 3 turns on the pinion for a 3.08 to 1 turn of the axle. The number represents a ratio of turns of the pinion to axle, like 3.73 to 1, or 3.73:1. 4.11 would be 4.11 turns per 1 turn of the axle.
cdowns has a valid point.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-04-2011, 09:07 PM   #6
cparman
sharp as a marble
Re: Gear ratio
I agree with CDOWNS, I would ask to remove the cover, and look for numbers on the ring gear. It SHOULD say something like 41-11, which would be a 411. If you see no numbers which I doubt, just count the teeth on the ring and pinion, bring a calculator, and divide the pinion by the ring gear and do the math. The other upside to pulling the cover is to look to see what the gears look like /// rusty, broken teeth, etc
cparman is offline   Reply With Quote
Old 01-04-2011, 10:17 PM   #7
skokie
skokie's Avatar
Re: Gear ratio
I agree with cparman and cdowns remove that cover and see what you got inside. Also if I remember this right the numbers on the gears are 40 13 is a 307 and 41 11 is a 373. Or divide the big number by the little one and there you go.
skokie is offline   Reply With Quote
Old 01-04-2011, 10:44 PM   #8
hayhauler71
hayhauler71's Avatar
Re: Gear ratio
I agree with the others, if I am going to buy I like to look first
Fuzzy
hayhauler71 is offline   Reply With Quote
