01-04-2011, 02:58 PM | #1 |
Do i need swaybar brackets with my current susp?
Im wondering if the brackets will make a difference in my from suspension. I ask because I've seen two different size brackets that cpp offers and I've also seen a few dropmember guys bolt the swaybar directly to the frame.
Im using cpp upper/lower lca's, 2"spindles, ss7 bags and the cpp swaybar. Posted via Mobile Device |
01-04-2011, 03:39 PM | #2 |
67-72 parts collector,…
Re: Do i need swaybar brackets with my current susp?
I'd bolt it directly to the frame.
01-04-2011, 05:46 PM | #3 | |
With 2-4" front drop, I'd use the 'short' brackets (if you have to get them), or install the bushings on the inside lip of OE brackets (if you already have them). With 5" or more front drop, skip the brackets.
01-05-2011, 04:02 PM | #4 |
I ended up getting the shorter brackets from ccp. Im using a sway bar from a '79 5/8 ton truck and guess its different that the stock one. (my truck didnt have a sway bar on it when I got it) If I bolted the sway bar directly to the frame the sway bar would hit the cross piece that goes under the motor. Did all 67-72 come with sway bars? The reason I ask is that I had to remove 1 rivit from each side and drill 1 hole on eack side for the brackets to mount up...
01-05-2011, 04:18 PM | #5 | |
Junior Member
frontstreetcycle on Instagram |
01-05-2011, 08:02 PM | #6 |
Bolt it right up to the frame... no brackets needed.
Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
