Old 01-04-2011, 07:51 PM   #1
planewhisperer
U.S. Army Green Beret Sniper
planewhisperer's Avatar
I could you some help
With my 72 C10 V8 running at idle, when I turn on the headlights the fuel gauge drops below empty, turn signal indicators become dim when that specific signal is used. My alternator is at 15.6 volts at idle. I have a internal regulator alternator. I was thinking that my system is not getting regulated properly. With the truck running at idle without the lights turned on, when I select any turn signal the gas gauge goes below empty. What do you think...........
"YOU CAN RUN AND YOU CAN HIDE, BUT YOU WILL JUST DIE TIRED"
planewhisperer is offline   Reply With Quote
Old 01-04-2011, 07:54 PM   #2
71swb4x4
71swb4x4's Avatar
Re: I could you some help
I think your cluster isn't grounded properly or your cluster isn't pinned correctly.
Did you switch from a dummy light cluster to a gauges cluster?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-04-2011, 07:58 PM   #3
planewhisperer
I changed the original style cluster electrical panel to the original configuration.
Old 01-04-2011, 08:03 PM   #4
71swb4x4
71swb4x4's Avatar
I am not following you (been a long day). What did you change?
Old 01-04-2011, 08:09 PM   #5
planewhisperer
Sorry, I changed the cluster circuit panel that has the copper internal wiring for the instrument lights, turn signal indicators etc........
Old 01-04-2011, 08:21 PM   #6
jlive68
It sounds as of u have a bad ground. sheck those out first.
1968 chevy
U.S. Navy
jlive68 is offline   Reply With Quote
Old 01-04-2011, 08:27 PM   #7
matt67350
matt67350's Avatar
Ground the cluster. Small ground wire from cluster to a good ground under the dash.
69 swb stepside, rebuild and upgrade in progress
matt67350 is offline   Reply With Quote
Old 01-04-2011, 08:42 PM   #8
planewhisperer
Thanks, I will do that tomorrow. I will let you know what happens. Again thanks for the help and information....
Old 01-04-2011, 09:11 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
i don't follow what it was you replaced, but if the interment panel was removed, then odds are you have a bad ground. Classic symptoms
Old 01-04-2011, 10:54 PM   #10
hayhauler71
hayhauler71's Avatar
Normal alternator voltage should 13.5 to 14.6 your 15.6 seems a little high
Fuzzy
hayhauler71 is offline   Reply With Quote
