Old 01-04-2011, 07:59 PM   #1
loridr
Lowering blocks with 15" wheels?
Still thinking about what to do with my rear suspension. I'm satisfied with my 4/5 drop.
Current setup is 5" rear springs without relocating shocks or doing a notch and I’m running the stock panhard bar.
Can I run 2" lowering blocks with 15" wheels?
If so, and I switch to 3" springs, that setup would eliminate any need for a notch, I could use the stock panhard bar and I wouldn't really need to relocate the shocks either, correct?
loridr is offline   Reply With Quote
Old 01-04-2011, 08:06 PM   #2
Mike J
vw guy & now c-10 guy
Mike J's Avatar
Re: Lowering blocks with 15" wheels?
well, i'm running 2" blocks AND 5" springs with a 15" wheel, so yeah it's definitely doable, i'm also running c-notch, adj. panhard bar and relocated drop shocks, so can't help you with that part of the equation...
'68 long fleet
Finally made some progress on the build!!!
My Build Thread
Mike J is offline   Reply With Quote
Old 01-04-2011, 08:21 PM   #3
loridr
Thanks Mike.
I thought that I'd seen in a thread where you couldn't, and the Porterbuilt trailing arm literature makes a point of saying that you can run their lowered arms with 15" wheels (they are a 3" drop though, not 2“).
So that I'm clear on my understanding of the implications of blocks: they essentially push the trailing arms down towards the ground and decrease the clearance between the trailing arm (actually the bottom of the U-bots) and the ground, correct?
Old 01-04-2011, 08:22 PM   #4
SCOTI
SCOTI's Avatar
2" blocks w/a 15" wheel will work but there will be scrub line issues (the bolts will dig into the ground) if you have a flat @ speed. 1.5" blocks won't contact the ground w/a flat unless the rubber comes off the wheel.
5" rear drop is 5" drop regardless of how you arrive there. You're correct & don't need the c-notch unless you put some serious weight in the bed.
5" drop w/springs only definitely needs shock relocators (or shorter shocks) & an adjustable (or modified) Panhard bar to properly center the rear-end. The Panhard bar will be @ an angle that is compromised. It will work but it won't be optimum & will make the truck feel squirrely when turning/cornering on uneven surfaces. The better solution is a Super (long) Track bar (Panhard bar) from Porterbuilt, ECE, or CPP.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-04-2011, 08:31 PM   #5
loridr
Scoti,
Do you see any advantage at all to going from the 5" springs to blocks plus longer springs? Or am I just back where I started? Wouldn't I at least get more spring and shock travel or am I missing something in my thinking?
With 3" springs and blocks would I still need to relocate the shocks? How about 1.5" blocks and 4" springs?
Old 01-04-2011, 08:44 PM   #6
SCOTI
SCOTI's Avatar
Scoti,
I feel you should keep the spring as long as possible for the best ride. Lowering blocks yield additional drop w/no effect on spring rate or shock travel so they should definitely be considered.
The 1.5" block & drop spring combo sounds like the best option. The 2" blocks would also work, but you need to know there could possibly be consequences w/that option.
I would prob do the shock relocation brackets or you could tweak the factory shock mounts to ensure the shock angle is as close to stock (optimum) as possible....
http://67-72chevytrucks.com/vboard/s...d.php?t=359399
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-04-2011, 09:05 PM   #7
loridr
Smile Re: Lowering blocks with 15" wheels?
Scoti,
Appreciate your help. Sounds like the way to go is:
1.5 blocks
4" springs
adjustable panhard bar
relocate shocks
One last question (at least until my brain starts doing another burnout )
What is the "optimum" shock angle? As close to vertical as one can get?
My dad and brother have been in the aftermarket leaf spring business all their lives and say that the best setup is one shock in front of the axel and one shock to the rear of the axel; that’s the setup on my Toyota Tacoma but it would look like crap on a hotrod .
Btw: believe it or not, Posies Superslider is my dad’s design, he basically gave it away to Ken.
Old 01-04-2011, 09:53 PM   #8
SCOTI
SCOTI's Avatar
Scoti,
1.5 blocks
4" springs
relocate shocks
Cool deal about your pops. I feel as close to vertical within the spacial constraints is the way to go. I seem to recall reading 35° is about where the shock starts to lose leverage.
I suggest using a long/super Panhard bar set-up & high quality shocks (KYB GR-2's on a budget; Bilsteins otherwise) for best results.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-04-2011, 10:38 PM   #9
loridr
He's a cool dude, holds 19 patents on various leaf spring suspension designs and components including what I believe was probably the first helper spring setup, the "Stanley Stabilator".
Anyway, thanks again for your help.
Steve
Old 01-05-2011, 01:21 PM   #10
vin63
It's Better With Nitro
vin63's Avatar
Here's a visual...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
