01-04-2011, 09:19 PM | #1 |
Tot Roddin'
M&H Wiring - Any experience with them?
I'm getting ready to place an order for a few wiring pieces and wanted to see if anyone has had any experience with their products/service.
http://www.wiringharness.com/ So, let's hear it. Nate
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
01-04-2011, 09:39 PM | #2 |
Re: M&H Wiring - Any experience with them?
yes i have, i brought there HEI conversion & lighting harness. it plug right up no problem, that was a few years ago, it was just like factory, my alterator is on the passenger side & i had to extend it go to the passenger side other than that,no problem
01-04-2011, 09:42 PM | #3 |
I purchased a complete wiring harness for my 1969 Firebird from M&H. Outstanding product and exact match to factory. I highly recommend them.
01-04-2011, 09:45 PM | #4 |
Tot Roddin'
Thanks guys... that is exactly what I wanted to hear.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 01-04-2011 at 09:47 PM. |
01-04-2011, 09:50 PM | #5 |
I rewired my entire truck with their stuff and had no issues. Would recommend them.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
01-04-2011, 09:56 PM | #6 |
Tot Roddin'
skokie, rcrahn: are the wires named on their full kits? Or do they provide you with a guide to the install?
Factory colors on all wires?
01-04-2011, 10:07 PM | #7 |
From what I remember they were identical to what I pulled out of my truck but in a lot better shape. Also forgot to mention that they are nice people to that will ask any question you throw at them. I must have spent 2-3 hrs peppering them with questions. Give em a call.
Hope that helps.
01-04-2011, 10:15 PM | #8 |
I used them and have nothing but good things to say about their tech. support...
engine harness headlight harness modified by M&H...headlite relay(hi, low beam), HEI & tach., electric water pump, alternator on passenger side, electric choke, electric fan The only thing I forgot about was larger size wires for the headlites, carries more current All connectors were correct for OEM, and correct wire colors Changed my '72 GMC front headlight harness to a '70 Chevy headlight harness. Make sure you keep your original harness and compare the part you get back from them to it...anyone can make a mistake, but its your truck that will suffer Follows factory wire schematic
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-04-2011 at 10:20 PM. |
01-04-2011, 10:50 PM | #9 |
A vehicle is broken down into several harness, each M&H harness is an exact copy of the factory harness, with the correct color wire and correct connecters. There is no guess work. The sub harnesses come individually packaged. As you remove one you replace and plug in the new. Simple.
01-04-2011, 11:02 PM | #10 |
What?
I rewired my 68 Suburban with all of their stuff.
I had a problem with a miss pinned plug, it drove me up the wall to tell you the truth. But their techie Darrin was a pleasure to work with, even though my frustration was high he was able to help get things squared away. I live within driving distance to their shop, so I took in my harness which they corrected in minutes free of charge of course. Even with my troubles, I'd recommend them. Since the product they sell is a perfect match to the OEM looms, and if you have technical questions/issues their tech support is top notch.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
01-04-2011, 11:22 PM | #11 |
Seems like decent prices too. I wonder how they are on shipping?
-Scott- |
01-04-2011, 11:28 PM | #12 |
Roadtrip!
I used them once for a tail light harness and it was very good. I will use them again.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
01-04-2011, 11:51 PM | #13 |
I have used several sets. Nice stuff and original looking.
55 Chevy original swb (big back window) 61 Chevy bubble top (427-5 speed) 67 Chevy stepside (Krusty) 68 Chevy swb fleet (Lola) 68 Chevy swb fleet 71 Chevy swb fleet ( future PB project) 97 crew cab power stroke 07 SS Trail blazer |
01-05-2011, 12:07 AM | #14 |
I have their stuff on my bb truck and it is as nice as the oem and looks exactly like it without the gm parts sticker. American auto wire and m&h were at one time partners and they split, their harnesses are alike and pretty strong competitors if I remember correctly. All plugs are as oem and are plug and play. Very nice parts. For the record the entire bb truck is wired with M&h and the 4x4 is wired in american auto wire- there is no difference in either set both are top notch!
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
01-05-2011, 12:48 AM | #15 |
Man of Mini-Talents
Good stuff, another recommend here.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
01-05-2011, 01:37 AM | #16 |
in case all those recommendations aren't enough for ya, I used their HEI engine harness on my 70, and their rear lighting harness. Nothing but great things to say about my experiences with that company.
1970 GMC 4x4 swb fleetside custom 4 inch lift with rear shackle flip, mild sbc, tci trans, rebuilt np205 w/twin shifters |
01-05-2011, 01:49 AM | #17 |
Used their engine harness- great quality, OE fit and finish
'70 GMC SWB step-side- 454, 4 speed, air bags (in progress) '09 CTS-V M6 '03 Sierra SWB Z71 '82 Yamaha Seca XJ650R Turbo! '04 Yamaha FZ6 |
01-05-2011, 08:25 AM | #18 | |
Tot Roddin'
Awesome guys, I really appreciate the info.
I have placed a rather small order, but the first of its kind. More updates to come. Quote:
Well for the one small wiring piece that I purchase shipping was pretty high (like 1/2 the cost of the harness) but... that is to be expected given the current economy.
01-05-2011, 07:16 PM | #19 |
10 minutes from my house. Great work, and the guys are always willing to help you out.
70 shortbed stepside "Schleprock" 350 w/TH400 rallys and BFGs -We can rebuild it, we have the technology-lower,shinier,faster |
01-05-2011, 08:44 PM | #20 |
sharp as a marble
they are awesome! I have installed sevsral of their harness, and never an issue!
01-06-2011, 01:34 PM | #21 |
oops double post
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." Last edited by 406 Q-ship; 01-06-2011 at 01:36 PM. |
01-06-2011, 01:35 PM | #22 |
I used M&H for the harness for my 68 Chevelle and they did some revisions for the change to Alternator on the right side. They also offered a new modern style fusebox (uses new plastic fuses) that I installed in my Chevelle. They are great people to work with and the harness is a bolt in just like the factory harness, not like those harnesses that you have cut off the connectors from a 40 year old harness to install on your new expensive harness. OEM GM color codes of the wires too. I use them exclusively for OEM rewire jobs.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
01-06-2011, 03:45 PM | #23 |
Project Junkie! Fishing Poor!!
M&H and US Autowire are all that we sell and use. They are the same harnesses with different names on them. I have totaly rewired 4 or 5 trucks over the past year or so with thier harnesses and never had a problem. I don't even bother to remove and replace as I go. I just tear it all out and install the new ones once I am done with the tear out. I have had a couple of customers complain about a misplaced pin like what happened to vectorit, but they helped them figure out the problem and always paid the freight both ways to fix them. You won't go wrong with their harnesses. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
01-06-2011, 05:02 PM | #24 |
Factory colors, factory connectors AND exact OEM length. Just use any factory wiring diagram. Be sure to tell them if you've modded anything. Each harness is made to order so it's very easy for them to accommodate an HEI dizzy etc.
01-06-2011, 08:20 PM | #25 |
Tot Roddin'
Thanks Fitz.
I'll keep you guys posted when it arrives; can't wait!
