Old 01-05-2011, 01:42 AM   #1
coggonobrien
if you had a choice what would you use for a 4x4 conversion
I am in the process of converting my 68 swb to 4x4. I have the option of either parting a rusted out but reliable 69 blazer (6 lug) or purchasing a mid to late 70's 3/4 ton 4x4 chevy with 8 lug. I will be going with either a 4 inch lift and 35's or 6 inch and 37's. the truck would be primarily a road use vehicle with some time spent driving through row crop fields and bucking snow drifts on gravel roads. would you go with the blazer 4x4 gear or the 3/4 ton truck. truck could probably be bought for 300 and i already have the blazer.
thanks!
David
coggonobrien is offline   Reply With Quote
Old 01-05-2011, 03:30 AM   #2
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
Re: if you had a choice what would you use for a 4x4 conversion
3/4T woulden even think about it
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 01-05-2011, 04:19 AM   #3
coggonobrien
ok, i'm assuming due to the longer spring length of the later series it ought to ride better
Old 01-05-2011, 11:09 AM   #4
Burt4x4
Burt4x4's Avatar
I would buy a mitltary 1Ton 4x4 Chevy P/U and swap it in.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 01-05-2011, 11:38 AM   #5
coggonobrien
ha ha yea, i will probably use 1/2 ton lift springs from a fear of one rough riding swb truck any thoughts on that? also the truck is receiving a 427bbc and a 700r4
Old 01-05-2011, 02:08 PM   #6
Burt4x4
Burt4x4's Avatar
Smooth ride + Chevy 4x4 = No way man hahhaa
Aftermarket spring packs will be the best way to get a smoother ride. You buy spring packs that have 6 or more thinner leafs rather than the harsher 3-4 thicker leafs per pack..you dig what I'm sayin?
I run SuperLift rear packs and they have 7 leafs w/teflon inserts to produce a softer smoother ride...
Old 01-05-2011, 03:17 PM   #7
coggonobrien
gotcha if you don't mind my asking how much lift and how much did you spend?
Old 01-06-2011, 11:03 AM   #8
monza1979
monza1979's Avatar
3/4 ton hands down, stronger axles, plus the possibility of an np205 (not sure if thats what it has, rather assuming). updated, stronger and cheap, kind hard to beat that!!
I had the right to remain silent, but i didn't have the ability!
78 chevy swb 4x4 sm465 np205 350 4" lift, ORD flip kit, ORD Ext. brake lines
79 Chevy Monza:current plans, dz 302, 4 speed
69 Pontiac Firebird: 74 s.d. 455 build up, m22 rock crusher
monza1979 is offline   Reply With Quote
Old 01-06-2011, 12:00 PM   #9
Burt4x4
Burt4x4's Avatar
I am running 4" Rancho in front and 5.5" SuperLift in rear. Plus 3" Bodylift.
Above pic (my son driving) the tires don't have much air pressure but they are 36" Irok Swampers...with Blazer's the Assend is way heavier than a P/U so that is why I have a taller rear pack to prevent the Ass-sag you may have seen on other Blazers out there...
As for $$...it's been 15yrs+ so...?? What I spent is probly not the going rate today...I think the rear packs were 400 er 450 in that area...the 4" Ranchos were on the K5 when I bought it in 1993 so??
Good Luck!
Old 01-07-2011, 07:01 AM   #10
1malo68
1malo68's Avatar
I have a 68 swb project in progress and I'm using a '79 3/4 ton 14 bolt full floater rear and a corporate 10 bolt front. I got my tough country EZ ride springs front and rear ( only a 2" lift ) from SDtrucksprings for $850 delivered. I can't say for sure, but they're supposed to have a good ride. Be ready for some spring perch and shock mount relocation on the rear though.
1malo68 is offline   Reply With Quote
Old 01-07-2011, 07:10 AM   #11
coggonobrien
gotcha, since i'm starting with a 2wd swb frame i'm kind of free to use whatever are you bolting your mounts or welding them to the frame?
Old 01-07-2011, 07:32 AM   #12
1malo68
1malo68's Avatar
Welding the mounts to a crossmember and double shear bolting it to the frame
Old 01-07-2011, 07:33 AM   #13
1malo68
1malo68's Avatar
my shocks will be at a 60 degree angle and mount just inside the spring perches
Old 01-07-2011, 07:35 AM   #14
1malo68
1malo68's Avatar
Where's Coggon? I have family in Crescent.
Old 01-07-2011, 08:02 AM   #15
coggonobrien
north of cedar rapids 30 miles, between highway 20, 380, 30 and 13
Old 01-07-2011, 08:03 AM   #16
coggonobrien
http://maps.google.com/maps?q=cresce...ed=0CBQQ8gEwAA
