Old 01-05-2011, 02:28 AM   #1
67chevy1series
67chevy1series's Avatar
72 gas pedal idea need a anwser
i have already painted my fire wall all nice like then i am in fromed that i must cut a square hole in my fire wall that is gonna look like $hit! can i just gety a cable hat is the same length ,but just has a circle peice on it so that way all i have to do is drill a circle hole could this be done if so when i go to buy the new cable what do i tell them?? thanks in advance
67chevy1series is offline   Reply With Quote
Old 01-05-2011, 10:41 AM   #2
Putter
More Cowbell....
Putter's Avatar
Re: 72 gas pedal idea need a anwser
I was forced to cut the square, too. I used a Dremel tool and a cut-off wheel. Turned out really good actually. Then just touch up the exposed metal with some paint. No one will even see it. Just mask off everything around it with a few layers of masking tape...in case your tool jumps. That will keep you from scratching the surrounding paint.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 01-05-2011, 10:48 AM   #3
pumpkin
pumpkin's Avatar
Lokar
pumpkin is offline   Reply With Quote
Old 01-05-2011, 12:06 PM   #4
76kcfdeng
I did mine by drilling a hole and then filing it square. If your careful you won't mess up the paint, use masking tape as suggested.
70 Chevy SWB Fleet Project.
06 Lancer Evolution MR SE, stupid fast!
03 Ford f-250 crew cab, 6spd, diesel
56 ford f100 project
My build thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=426739
76kcfdeng is offline   Reply With Quote
Old 01-05-2011, 12:58 PM   #5
72MARIO
72MARIO's Avatar
Lokar.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-05-2011, 03:14 PM   #6
hotrodimpy
67chevy, Call us here at Lokar toll free 877-469-7440. Ask for Jeff in Tech and he can help you out. With our throttle cables you will only drill one 5/16 diameter hole. our Throttle cables are cut to fit and come in Black, Stainless Steel and Black Stainless Steel with Black fittings. If you do chip your paint around we have a bezel trim washer also. You will need a spring return bracket to go with this cable for the carb side.
Thanks Impy
hotrodimpy is offline   Reply With Quote
Old 01-05-2011, 06:51 PM   #7
67chevy1series
when i get the pedal and am about to in stall i will be calling you!
Old 01-05-2011, 06:53 PM   #8
1970 CST STEP
Originally Posted by pumpkin View Post
Lokar
Problem solved
1967 SWB (small window) original
1970 4x4 STEP
1970 CST SWB FLEET
1972 SWB FLEET ORIGINAL
1970 CST STEP is offline   Reply With Quote
Old 01-05-2011, 08:31 PM   #9
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Thanks Impy
nice to know we have some Lokar support here!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-06-2011, 04:02 PM   #10
hotrodimpy
Anytime there is a question on Lokar product Please use our toll free number
877-469-7440 that is why it's there. We offer a lifetime warranty on all products and there made in the USA. If you have a question with product selection give us a call and we will get you the correct part numbers and a dealer near you.
Thank you Impy
