Old 02-28-2002, 02:37 PM   #1
Cliff25
Question Disk Break Conversion?
I'm looking for a rear disk brake conversoin for my '76 Truck. Can anybody help?
Cliff25 is offline   Reply With Quote
Old 03-01-2002, 07:11 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Talking
Cliff25,
There are several options for you. You can build your disc brakes from parts availalble, buy kits or swap the rearend. The easiest will be to swap the rearend. You can use a Cadillac or Lincoln Continental rearend. Using one of these will align the travel path of the front tires with the rear tires. The next option is to buy brackets from people who make them then bolt Corvette or Caddy parts on to your original rearend. I've seen brackets available on www.ebaymotors.com
The more expensive option is to buy a kit. The best I've found for the price is available from Hot Rod Brake Systems . They use Corvette brakes or caddy brakes. Other kits will cost you over $600.00. The Hot Rod kit will cost you less than $500.00. If you do the conversion, I would like to see some pics. I've thought of doing the same thing.
Gerardo
1983 Custom Truck
TX Plates: "BAD BOW"
http://www.geocities.com/abetterchemist/
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 03-05-2002, 11:49 PM   #3
trukman1
Post
How about a little more info on the rear differential? Is it a 12-bolt,14-bolt FF? All this effects your options and may elicit more responses. Just trying to help.
1967 K30 461/TH400/Np205/D60/14FF/BDS
MTZ 375/75/16 on 16x10 Pro Comps
trukman1 is offline   Reply With Quote
Old 03-06-2002, 07:09 AM   #4
gchemist
gchemist's Avatar
Talking
Cliff25,
I assume the '76 truck is a 1/2 ton SWB or LWB. If so then the rear is more likely to be a 12 bolt. 3/4 ton or 4X4 will probably have different axels.
Gerardo
1983 Custom Truck
Old 03-06-2002, 01:52 PM   #5
Cliff25
Post
Its a '81 12 bolt rear end with 3.07 gears. The trucks a '76 C10 SWB registered as a '73 to get around California's bull**** smog requirements ('73 and older are exempt). Sorry about the lack of specifics, I'm new to this forum thing. I did find some brackets on e-bay, thanks gchemist.
Old 03-06-2002, 02:59 PM   #6
gchemist
gchemist's Avatar
Talking
Hey, I have 12 bolt 3.08. I removed the stock 2.72 10 bolt. Looks like this now.
Cliff,
Can you provide some pics of the brackets?
Gerardo
1983 Custom Truck
