01-05-2011, 11:14 AM | #1 |
C35 Crew Dually
LTB Wire harness
Looking for a Wire harness for my 1984 CC LWB Dually
From what i read i need a 81-87 Truck I need (willing to buy separate or all together) Fire wall to tail light harness (does not have to be dually i can wire in the Flare lights) Dash harness (FOR A GAUGE CLUSTER) and a Motor harness for a 350 (for gauge cluster set up)
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 |
01-06-2011, 09:42 AM | #2 |
C35 Crew Dually
Re: LTB Wire harness
Bump anyone?
01-07-2011, 02:12 AM | #3 |
Will one from am 86 305 auto work ?
01-07-2011, 10:25 AM | #4 |
C35 Crew Dually
I'm pretty sure for the tail lights an the dash (as long as they are gauge ones.) I will look up the motor harness
01-07-2011, 10:59 AM | #5 |
C35 Crew Dually
Apparently it should. D you just have all the harnesses i need or just the motor and how much?
01-16-2011, 06:16 PM | #6 |
C35 Crew Dually
Bump
02-07-2011, 04:13 PM | #7 |
C35 Crew Dually
TTT still looking for the motor harness.... anyone?
02-07-2011, 04:17 PM | #8 |
I have a complete wiring harness out of a 1986 shortbed with a 305 in it.......will that work??
02-07-2011, 04:20 PM | #9 |
C35 Crew Dually
Auto trans? and what kinda cluster did it i have? guges or warning lights?
02-07-2011, 04:22 PM | #10 |
700r4 tranny and the cluster was gauges, clock, water temp, oil pressure, speedo, fuel gauge
02-07-2011, 04:24 PM | #11 |
C35 Crew Dually
How much? sounds like what i'm looking for all un cut and unmolested? you would not belive the harness thats in my truck right now i don't know how it's running :S
02-07-2011, 04:35 PM | #12 |
do you need everything the under dash harness,engine harness, headlights, and fuel tank harness??
02-07-2011, 04:37 PM | #13 |
C35 Crew Dually
just engine and fuel tank harness. just picked up a in dash harness dirt cheap.
02-07-2011, 04:38 PM | #14 |
I need 75 bucks plus the ride
02-07-2011, 04:39 PM | #15 |
C35 Crew Dually
Can you get a quote to belleville ont canada k8n 1a8? thanks.
02-07-2011, 04:40 PM | #16 |
Yes it should be no more the like 20 bucks but i can get a quote....
02-07-2011, 04:43 PM | #17 |
C35 Crew Dually
just trying to see if it's going to be woth it. i just picked up the dash harness for 5 bucks.
