01-05-2011, 12:43 PM | #1 |
disc or drums pleas help
I'am having a hard time deciding if i should wait off doing the disc conversion and put my money into other stuff i will need to do so i can get my truck back on the road. What do you guys think? Conversion total would be $2,250 including the boss 338 in a twenty.
Josh 1968 C-10 Shortbox |
01-05-2011, 01:04 PM | #2 |
'67 C-10 LWB Driver
Re: disc or drums pleas help
hey there Josh,
i know the feeling...i have a 67 with all drums. i think that i have decided to hold off and just get all of the drum brakes working good and see how it goes. it's more important to me to get the sheetmetal fixed, all of the suspension and drivetrain running well. make sure all of my mechanical stuff is safe and operating correctly first and then i can start to do some of the custon stuff...lowering it, converting to disc brakes, power steering etc. my $.02 worth.... Jason
'67 C-10 LWB - My Build Thread '67 C-20 LWB - My Donor/ Parts truck - SOLD! '92 GMC SAFARI VAN - My Parts Go Getter '06 KIA SPORTAGE EX - My Commuter "All of this crap better make a truck!" - my wife Sue. Proud U.S.M.C. Dad! |
01-05-2011, 01:19 PM | #3 |
Just remember BRAKES are the most important part of your truck! I would do the brakes before I do the rest. I run 4 wheel discs and will never have it any other way. .02
01-05-2011, 01:20 PM | #4 |
I think that is the way i"am leaning towards because i can get the truck done if i dont do the breaks.
01-05-2011, 01:26 PM | #5 |
Florida Edition
I'm with Greg...did all the suspension FIRST....you'll love those disks when the little princess on the cell phone pulls right out in front of you!
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
01-05-2011, 01:50 PM | #6 |
why not put a 73-87 front end on the truck to get disk breaks? i think power breaks would be something to look into because the stopping will be 1000 times better an it isnt hard to do.
1969 Chevy c20(Miss Hackjob) |
01-05-2011, 02:05 PM | #7 | |
Roadtrip!
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
01-05-2011, 02:20 PM | #8 | |
67-72 parts collector,…
Skip the freakin 20's and get your brakes working.
01-05-2011, 07:12 PM | #9 |
X 3!!! More important than wheels/tires
1967 SWB (small window) original 1970 4x4 STEP 1970 CST SWB FLEET 1972 SWB FLEET ORIGINAL Last edited by 1970 CST STEP; 01-05-2011 at 07:14 PM. |
01-05-2011, 07:57 PM | #10 |
Well it sounds like the right thing to do is brakes. I guess i will just have to wait on wheels and tires.
01-05-2011, 08:00 PM | #11 |
Dave's not here, man
It never ceases to amaze me how many times I see a vehicle sitting on the side of the road with a set of nice wheels because money was spent on looks rather than making the vehicle mechanically sound. You can swap to disc brakes relatively inexpensively if you do as mentioned above and find a donor truck. Personally, rims would be the very last thing I would worry about.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
01-05-2011, 08:36 PM | #12 |
its all about the +6 inches
on top of the facts mentioned above, if you set up the suspention first, then you can get the wheels for that suspention. Even if you spent the (much) added cost of 6 lug disks, the track is wider when you convert, and the wheels you stuffed in the fenders will be smacking the fenders.
Also, it is human nature to put things off. If you get your ride all pretty and running good, and then start having fun putting dead bugs on the grill... you are WAY less likely to pull it all apart and do a big mod like this. When the truck is apart, it's a fairly simple small mod. But when it is all done, fresh paint, everything bolted in its proper location, then it is VERY easy to say "Eh, the brakes are good enough." This is the main reason my one ton STILL has drums. It's easier NOT to do it. Do it now. |
01-05-2011, 10:38 PM | #13 | |
01-05-2011, 11:46 PM | #14 |
yep... good enough for now ends up being good enough.
01-06-2011, 12:57 PM | #15 |
ya thatmakes since might as well do brakes while its all taken apart i see its way easier to get too everything that way, and i would porbably keep putting it off if i go the other way.
01-06-2011, 02:43 PM | #16 |
the boat guy
gas is expensive, once you start driving the wheels off of your truck you might not be able to afford any other mods
find a parts truck, I got everything I needed to swap from drums to disc 4 wheels and tires for $600, sold engine and trans then sold the bondo to the srap yard at the price of steel. brakes brakes brakes brakes brakes brakes.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
01-06-2011, 02:57 PM | #17 |
I am (was) in the exact same situation you are. I went ahead and did the disc conversion (already had factory front discs) becasue the old drums were in such bad shape it was going to require replacing everything anyway. I'm happy knowing that even though she is still in need of paint and bodywork, she will run strong and stop on a dime. That means I can drive it in the mean time without worry.
01-06-2011, 03:06 PM | #18 |
Old Skool Club
Brake upgrade/conversion was the first thing I did. Never regretted it. Still don't. Wheels? You will probably change your mind several times by the time you are ready for them. Don't get stuck with a wheel design that you may not be in love with then, as you are now.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
01-06-2011, 05:35 PM | #19 |
What parts from what vheicals can you use to convert to rear disk breaks? i thought you had to buy a aftermarket kit...
1969 Chevy c20(Miss Hackjob) Last edited by treveiger; 01-06-2011 at 05:37 PM. |
01-08-2011, 02:14 AM | #20 |
I think treveiger is right you dont need to spend a lot of money, why don't you swap 73-87 disc brake system, I did it.
CPP has an article how to do it. the only xtra parts you'l need are ball joints, brake lines and outer sleves as well as an special adjusting sleeves. But again see the article how to swap 73-87 disc brakes, it has a lot of pictures. |
01-08-2011, 02:32 AM | #21 |
I added a hydroboost unit to my brakes. One of the best investments I have ever made.
01-08-2011, 12:00 PM | #22 | |
Junior Member
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
01-08-2011, 07:03 PM | #23 | |
Thanks.
01-08-2011, 07:25 PM | #24 |
CPP = www.classicperform.com
01-08-2011, 08:54 PM | #25 |
thats awesome thanks!!!
