Old 01-05-2011, 12:59 PM   #1
brothers69c-10
Suburban Hick
brothers69c-10's Avatar
Knocking noise?
I finally have my 78 k10 back on the road with the 427 tall deck. I completely dismantled the motor and put all new bearings, gaskets, cam and lifters, timing chain set and new push rods in the motor along with honing the cylinders cleaning everything up. Now that the truck runs and drives i have developed a noise that sounds like a knock or chattering. I first noticed it when i drove for the first time. the noise only came about when the engine was under load goind down the raod. it could not be heard idling or even when putting the truck in gear and holding the brake while giving it gas. it originally sounded like a rocker arm chattering so ifigured no big deal put about 50 miles on it then readjust all the valves. Now its got the 50 miles on it and the noise has progressively gotten louder and can now be heard while idling. Also it now sounds more like a knock. If you give it some gas it will sound more like a rocker chattering while going down the road. I crawled under the truck while it was running and the noise was louder underneath and almost seemed to be coming from the bellhousing area of my transmission. I have checked for exhaust leaks and have none, there are nos signs of metal or any contaminants in my oil, and all my other fluids have been topped off. the only other wierd thing the truck is doing is that when you put it clear to the floor it starts shaking real bad and won't exceed 2800 rpm's. I'm sure that part of this is due to the kick down not being hooked up, but it did the same thing with the last motor that was in it only worse cause it was a heftier built motor. I'm afraid to drive it too much for fear ruining something. I've already dropped a ton of money in this darn thing and can't afford to put much more in it right now, but we could really use an extra 4x4 around the house. So if you guys have any suggestions i would be happy to hear them and will try to provide all the information i can.
Mathew
1947 Chevy 3600
1951 GMC 100
1969 Chevy C-10 396/500hp TH400 lowered 4"
1968 Imapla Custom 396/325hp TH400 "Grandmas Car"
1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505
1978 Chevy K-10 454
1983 S10 4x4 "Bumblb" (Grandpa's truck)
1993 Chevy S10 V8 conversion
1990 Ford Probe Gt
1992 Dodge W-150 "Old Man's Truck"
1992 Pontiac Grand Prix SE
1992 Mercury Grand Marquis-Mercruiser
2000 Ford F150 (Currently my mother drives this)
1946 Farmall H with Stan Hoist loader
1965 John Deere 110
1961 Wheel Horse " Rat Tractor"
brothers69c-10 is offline   Reply With Quote
