Old 01-05-2011, 03:19 PM   #1
roofingbloke
Your opinions needed
Your opinions are needed on the following please,
Last august i posted a want ad on the Uk NSRA forum for a T5 gearbox,
Darl from Fasco contacted me with the following;
Originally Posted by Dr.Dee
Darren... just sent 5 speed MUNCIE trans to UK.... from 2002 S-10 VERY STRONG trans.... much stronger then any T5 stock... custom cannot use with his FLAT HEAD FORD.... up for grabs
PRICE 445 GBP TAKES HERE...... can send details
Regards Daryl
http://i4.photobucket.com/albums/y14...NSMUSTSELL.jpg
Sounds good, ? will this have a mechanical speedo drive or an electric speedo drive as i have Dolphin guages that are mechanical,
My engine No is 970010 (front) V0225cnv (rear)
I think its a 350ci from a 1970 caprice.
Thanks Darron
Darron i believe it is a ELECTRIC speedo... BUT can be changed to mechanical drive easy swap
your block is OLD SCHOOL 010 block excellent core to start a rebuild..
Can connect you to Chris with trans... he ONLY wants what hes got into it 445 landed UK is a steel... these trans are easy 2X stronger then any stock T-5 BW trans.. that BLOW 2nd gear with often with some HP & torque ...
Cheers! Daryl
Ok Daryl i will have it, Thanks. Darron
I picked up the gearbox and have only untill now noticed that the gearbox is not as i was sold, I turns out to be a New venture 3500, I have contacted Daryl at fastco and here is my reply.
Fastcoauto@aol.com to me
show details 4:27 PM (2 hours ago)
Go ahead a blame others for your mistakes.... it's a lot easer ...you did not check..trans for your application before your bought it & now 6 months after you bought trans is now not what you want to use ............... fine sell it and move on....
So guys your opinion is needed thanks.
roofingbloke is offline   Reply With Quote
