Old 01-05-2011, 04:18 PM   #1
darkone
Biggest Wheel on Stock 1970 chevy 3/4 ton
just wondering, what is the biggest rim im going to be able to put on a 1970 chevy c20 stepside long bed? the truck is stock and has no lift. thanks!
darkone is offline   Reply With Quote
Old 01-05-2011, 04:59 PM   #2
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: Biggest Wheel on Stock 1970 chevy 3/4 ton
Widest, largest diameter, or both?
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 01-05-2011, 05:02 PM   #3
darkone
how bout both? =) i want some fat rims with some tires as lo pro as i can go
Old 01-05-2011, 05:18 PM   #4
tubbedII
needs more $$$
tubbedII's Avatar
Donk?
28"x10" wheels with a 335/20 will be 33.3" tall...ewww...sorry, just not my taste...
Here's the link to a tire size chart: http://www.rimsntires.com/rt_specs.jsp
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 01-06-2011, 10:16 AM   #5
I've run 12.50/33" rubber on the back. Never wanted to go with the frail look,though. The wheels were 10"
Old 01-06-2011, 03:40 PM   #6
Jacfourteen
I have 31x10.5 on mine right now with I think an 8" wide rim and there is lots of room with my 4" of drop. Like stated above I figured a 33" tall tire wouldn't be a problem. Not sure on if you go bigger wheels, not too many people on here running big wheels on 3/4 tons.
Old 01-06-2011, 10:21 PM   #7
72MARIO
72MARIO's Avatar
I have 285 75 16 on my lifted and they are really close to touching the front fender when I am loaded. but they clear. they measure 32.5
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 08-13-2011, 07:35 PM   #8
darkone
^^^ looking for tires today and tomorrow..... so 32 is about the biggest i can go prob?
Old 08-13-2011, 08:52 PM   #9
Frkypunk70
Frkypunk70's Avatar
Pretty sure you can run wagon wheels on a c20 with a stock suspension
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. "
Frkypunk70 is offline   Reply With Quote
