01-05-2011, 04:47 PM | #1 |
Need pictures of ....
.... installed rear pinon adjustment shims. TIA
R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-05-2011, 05:12 PM | #2 |
Re: Need pictures of ....
Kind of hard to get a picture of, they are just sandwiched between the bearing and the base of the helical cut gear. Does that make sense?
Brett |
01-05-2011, 05:19 PM | #3 |
Rob,
are you playing with a rear end?
01-05-2011, 05:22 PM | #4 | |
i believe he is talking about the wedge shaped shims that go between the trailing arms and the rear end mounting perch to adjust the pinion angle to the right degree Last edited by project 67 sub; 01-05-2011 at 05:23 PM. |
01-05-2011, 05:38 PM | #5 |
Gotcha! I was thinking pinion depth, not angle.
Brett |
01-05-2011, 05:41 PM | #6 |
haha no problem lol.
01-05-2011, 07:04 PM | #7 |
What specifically are you looking for?
01-05-2011, 08:00 PM | #8 |
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
01-05-2011, 09:42 PM | #9 |
Do you have any pictures of your shims installed? I just want to make sure I put them in the correct way......
01-05-2011, 09:59 PM | #10 |
They go between the rear-end housing 'pad' & the truck arm 'pad'. Which direction depends on which way you're trying to go. Mine are installed to yield 3° positive pinion angle.
The 1st pic is a 3/4 view from the front of the housing (driver side). 2nd pic is a 3/4 view from behind the housing (again driver side). Also note a little subliminal PB endorsement ....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-05-2011 at 10:02 PM. |
01-06-2011, 09:54 AM | #11 | ||
01-06-2011, 11:11 AM | #12 |
I dont want to hi-jack Rob's thread, but would like to add more discussion to this topic.
When setting the pinion angle on a leaf spring rear, you allow for flex in the leafs so that the pinion angle matches the tranny angle while under load. Since our trucks use trailing arms and dont flex (much), are you guys allowing for any extra degrees or are you matching your pinion angle equal and opposite of the tranny angle? I almost bought those shims from stock car products, but had my cpp drop block machined so my pinion angle is the same angle as my tranny instead. Last edited by dznucks; 01-06-2011 at 11:15 AM. |
01-06-2011, 11:30 AM | #13 |
I haven't gotten the drivetrain in yet but my plan is to adjust the height @ the trans x-member if needed.
01-06-2011, 11:34 AM | #14 | ||
Roger that. I also notices that you flipped the trailing arm mounting brackets on your ECE crossmember. How much does that help on the pinion angle?
01-06-2011, 11:46 AM | #15 | |
But, my 68 had the same basic set-up (but the rear clip was in the OE location), & I know my pinion was not optimum w/the factory orientation (it was driveable w/o vibration using a 1:1 final drive ratio, but not optimum). Since this truck is getting OD, I wanted to ensure the angles are correct because I can't stand driveline vibration & it becomes much more prominent w/OD. With the rear clip raised 3" vs OE, I needed the front pivot point raised a similar amount. Flipping the mounts raised the pivot point approx .500-.750" vs. OE placement of the rails.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-06-2011 at 12:05 PM. |
01-06-2011, 12:15 PM | #16 | |
Pro Touring 1964 C10-Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=441627 Project '65 Short Step Daily Driver http://67-72chevytrucks.com/vboard/s...d.php?t=661948 |
01-06-2011, 01:02 PM | #17 |
If using a 1pc driveshaft, I think the 'opposite angles' is what's common.
01-06-2011, 02:34 PM | #18 | |
01-06-2011, 03:59 PM | #19 | |
do you mean the angle should be one degree less than or greater than the tranny angle? ie. if the tranny is at 4* down, should the pinion be 3* up or 5* up? |
01-06-2011, 04:43 PM | #20 | |
http://67-72chevytrucks.com/vboard/s...g+pinion+angle
01-06-2011, 11:12 PM | #21 |
This will be fun to figure out on mine. How does this relate to a two piece drive shaft? Once I get panhard bar mount done this is next.
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
